Are fuel injector connectors injector specific?
Old Sep 20, 2001 | 11:17 AM
formul8!!'s Avatar
Car: 2004 GTO
As far as my knowledge, TPI's are batch fire. According to the wiring diagram, all the injectors main lead wire is one wire that splits in to 4 that lead to the injectors.
My question is, if I mixed up the injectors plugs, then it shouldn't matter because they all fire at once?
Old Sep 20, 2001 | 11:55 AM
doc's Avatar
doc
Car: '87 IROCZ
Engine: 395 ZZ4
Transmission: ProBuilt 700R4
Axle/Gears: 9 bolt 3.70s
I'm not 100% sure, BUT on the same bank, it should not make any difference which connector goes to any injector on that same bank.
'87 L98 TPI IROCZ, AFR190 heads, 3.70 gears, ZZ9 cam, 3000 Art Carr TC, SLP 1 3/4" headers, SLP cat-back, no cat, no AC, no MAF screens, Accel manifold base & SuperRam, 24#/hr SVO injectors, Edelbrock double roller timing chain, MSD ext coil & distributor, trans cooler, 52mm TB with airfoil, TB coolant bypass, AFPR(50psi), K&N filters, Hotchkis lowering springs, my custom chip, Lay Ind. ram air kit, SS Brakes 1LE upgrade 12" rotors dual piston calipers, 265/45R16 Kumho V700 tires.
ET 13.27sec @ 103mph on MT ET Streets
'90 Eagle Talon AWD, no rust thru 9 winters
'99 Camaro SS, red, 6-spd, T-tops, Mcleod clutch, Pro 5.0 shifter, MAF processor, Direct Flow airlid, K&N filter, next mod: 4.10 rear gears
313.7Hp & 320.6ft-lbf, ET 13.55sec @ 105.1mph
Old Sep 20, 2001 | 12:38 PM
Guest
Guest
Posts: n/a
Doesnt make any difference where you hook them up.
Old Sep 20, 2001 | 02:09 PM
formul8!!'s Avatar
Car: 2004 GTO
That's what I suspected.
Thanks!
Frozer!!!
Jan 19, 2024 04:55 PM
midge54
Dec 27, 2019 04:14 PM
Andrew6.688
Dec 13, 2015 10:59 AM
justin57
Aug 20, 2015 07:05 PM
ezobens
Aug 19, 2015 10:29 PM
