Possibly the wrong board, but, PROM / Cranking
Old Sep 21, 2001 | 07:32 AM
88gta305's Avatar
Car: 77 Corvette
Engine: ZZ3/nitrous
Transmission: THM 400
I replaced the 305 for a 350, and everything worked OK. I have just replaced the 305 PROM with a 350 PROM (Brand new GM), and now, when the car has sat for any length of time, it takes a lot of cranking to start the engine. The fuel pump can be heard to run.
Any suggestions.
BTW, I am still running 19# injectors, and this engine does have the CS injector
Cheers
Richard
Old Sep 21, 2001 | 10:48 AM
Desert86Roc's Avatar
Did you increase the fuel pressure to make up for your lack of 22# injectors? If not, that is your problem. Get the correct size injectors, or an adjustable fuel pressure regulator.
Old Sep 21, 2001 | 12:49 PM
88gta305's Avatar
Car: 77 Corvette
Engine: ZZ3/nitrous
Thanks for the quick response.
Interesting, I never thought about that.
Now to find some injectors.
Cheers
Richard
Caspar
Jun 19, 2016 11:19 PM
mddaniel
Sep 8, 2015 05:16 PM
Keith5
Aug 27, 2015 04:37 PM
Armored91Camaro
Aug 25, 2015 12:01 PM
