Need Vacuum Port Help
Old Sep 22, 2001 | 01:31 PM
Mrfixit's Avatar
I'm trying to sort out all the vacuum ports on my 89 TPI and I'm stumped. On the right side of the throttle body there area two ports; large and slightly smaller. I know the larger one (on top) is for the line coming from the right side valve over but what does the smaller one go to?
Thanks,
Roy
Old Sep 22, 2001 | 05:11 PM
rezinn's Avatar
The top one goes to the breather on your passenger side valve cover. If thats no longer there, just plug it. The lower one loops beneath the throttle body and connects to the charcoal canister. Don't forget the small nipple on the bottom of the throttle body, that connects to the egr solenoid.
Old Sep 22, 2001 | 05:56 PM
Mrfixit's Avatar
rezinn,
Thanks. Since I'm installing the motor into a 68 Camaro, the charcoal can and smog pump are gone. So, I guess I can just plug it off.
Thanks again,
Roy
Old Sep 23, 2001 | 11:22 AM
Vader's Avatar
Mr. F,
Maybe this would help:
You probably don't have one stuck to the underside of the hood on your '68...
Later,
Vader
Justice and Freedom will Prevail
Pac J
May 17, 2020 10:44 AM
FormulasOnly
Jul 23, 2018 08:47 AM
Mark_ZZ3
May 24, 2018 01:02 PM
sammy52401
Nov 11, 2015 07:20 PM
Reid Fleming
Oct 10, 2015 09:56 PM
