anti-freeze & 02 sensors
Old Sep 25, 2001 | 10:37 PM
whiteroc's Avatar
The TB coolant bypass hose busted going down the interstate last week. I noticed that the duct for the MAF was loose after I saw the anti-freeze dripping out of it when I took it off to fix the hose. I have no idea how much A-F the engine sucked in on its short drive to the reststop. My question is -Does the 02 sensor give false readings with A-F cooked on to it? I have heard that the A-F turns into silica/silicon? and prevents the sensor from reading the A/F correctly. Or? does it make any difference?
89 IROC-Z 5.7L 2.77 GEARS
130,000 MILES
ALL FREE MODS
K&Ns FILTERS
FLOWMASTER MUFFLER
PERFORMANCE RESOURCE CHIP
AFPR & PORTED PLENUM
Best 1/4 E.T. 14.09 @ 97.2 MPH
Best 1/8 E.T. 9.09 @ 77.4 MPH
Best 60ft. 2.03
[This message has been edited by whiteroc (edited September 25, 2001).]
Old Sep 25, 2001 | 10:41 PM
88 350 tpi formula's Avatar
Car: 89 FORMULA 350, 91 Z28 Convertible
Engine: ls1, LB9
Transmission: t56, Auto
Axle/Gears: S60/ 3.73
not sure on the o2. just you are really lucky! of course too much would lock up your eng. even a little could cool a pistion too quick crack a ring or bend a valve. old timers barly use any water to clean carbon out of an eng.
Old Sep 25, 2001 | 10:48 PM
whiteroc's Avatar
<font face="Verdana, Arial" size="2">Originally posted by 88 350 tpi formula:
not sure on the o2. just you are really lucky! of course too much would lock up your eng. even a little could cool a pistion too quick crack a ring or bend a valve. old timers barly use any water to clean carbon out of an eng.</font>
Well then I'm REALLY glad all of that cool gas going into the engine for the last 133,000 miles did'nt crack anything -wheewhw!
Old Sep 26, 2001 | 02:01 AM
rezinn's Avatar
You're right, coolant kills o2 sensors. I speak from experience. Atleast your spark plugs are clean now.
Old Sep 26, 2001 | 04:03 PM
breathment's Avatar
yup, they don't mix to well.
- David
88' GTA 5.7L TPI MODS---&gt; air foil, K&N, Shift Kit, 180* therm, TB bypass, Gutted CAT, Flowmaster 80 Series
Old Sep 26, 2001 | 09:07 PM
Engine: ls1, LB9
whiteroc what I am saying is the water really cools stuff off quick and you use less gass than you think.
HoosierinWA
Oct 7, 2015 10:15 AM
aaron7
Sep 30, 2015 09:15 AM
HoosierinWA
Members Camaros
Sep 29, 2015 12:43 PM
dusterbd
Sep 29, 2015 08:40 AM
SS-EXPRESS
Sep 28, 2015 09:14 AM
