AFR 190cc Question
Old Sep 26, 2001 | 05:09 PM
JR4444's Avatar
AFR 190cc Question
My friend has a set of heads: "190cc Street Heads, Angle Plug, 68cc" On the website the only difference in the description is "L98 Angle Plug" which are the heads I might need; instead of just Angle Plug. So my question is Will these heads work or can I modify those to fit? Thanks
88 Formula 350
Upper and Lower SuperRam, 1000 CFM Accel Throttle Body, 24# Motorsport Injectors, Custom Burned PROM, Larger Gutted Mass Sensor, MSD 6a box, Flowmaster Muffler, Homemade Cold Air induction, TB Bypass, B&M shift Kit, 160* Thermostat
Old Sep 26, 2001 | 05:55 PM
robert1's Avatar
Yeah, they'll work fine. Depending on engine stats, they MIGHT be too big, but the AFRs don't suffer from that like others. I have some 195s on my L-98,and they work just fine.
Old Sep 27, 2001 | 01:32 PM
STUB25's Avatar
The angle plugs are the L98 and they recommended the L98 angle plugs first off for stock L98 engines but if not a L98 if you are thinking of running SLP or Hooker headers because they give you easier access to the plugs
Old Sep 28, 2001 | 10:28 AM
Drakar's Avatar
So if you ran SLP Headers then get straight plug AFRS???
1989 Trans Am GTA, L98 5.7L TPI, TH700-R4, T-Tops, dual cats, 9-bolt rear, 3.27,
- K&N Air Filter
- Dynomax muffler
1992 Camaro RS, LO3 5.0L TBI, T-5, T-Tops, 3.08, L69 Dual Snorkel - Sold
- K&N Air Filter
Honda engines ROCK, I have one on my lawn mower but I still have to push it.
Old Sep 28, 2001 | 03:56 PM
Dan87IROC-Z's Avatar
I think the L98 angle plugs are for the Corvettes, just get the 64cc chamber straight plug heads.
1987 Chevy Camaro IROC-Z
L98 TPI 350 (5.7L)
TH 700R-4 Transmission
Borg Warner 7.75" 9 Bolt Rear End with 2.77:1 Gears.
Current Mods: LT4 HOT Cam, Comp Cams 1.52:1 Roller Rocker Arms, Accel High Flow TPI Baseplate, Edelbrock TES 1 5/8" Headers, Catco 3" High-Flow Catalytic Converter, Hooker 3" Aerochamber Cat-Back System, Transgo Shift Kit, Performance Resource Chip, Accel Ignition, K&N Filters, Jet TPI Air Foil, All Free Mods, Falken ZIEX Z-Rated Tires.
Best ET: 14.32 @ 97.7mph
(corrected for elevation)
Old Sep 28, 2001 | 09:31 PM
TRAXION's Avatar
Car: 2005 Subaru STI
Engine: 153ci of Turbo Power!
Transmission: 6-Speed
Do NOT get the straight plug heads. Get the L98 angle plug heads. Geez.
Tim
TRAXION's 1990 IROC-Z
Best Time = 12.244 @ 112.51mph (1.778 60' / 7.819@88.32mph in the 1/8)
All Natural. No Force. No Drugs. Stock Bottom End. Stock Body Panels.
Gunning for NA 11's with bigger cam, bigger stall, and bigger exhaust.
-=ICON Motorsports=-
Moderator: PROM board at thirdgen.org
LT1Formula
20
Nov 14, 2015 12:02 AM
gixxer92
Sep 1, 2015 04:32 PM
redmaroz
Aug 16, 2015 11:40 PM
89mulletbird
Aug 12, 2015 07:08 PM
89mulletbird
Southern California Area
Aug 10, 2015 10:16 AM
