What size injectors should i use?
Old Sep 28, 2001 | 11:50 PM
87Iroc-z's Avatar
Car: 1987 Z28
Transmission: 700-R4
Im replacing my injectors this winter and a friend of brought up the point of going with 22# or maybe 21# from accell. You can see my mods here. http://www.jw-performance.com/1987%2...o%20IROC-Z.htm
Old Sep 29, 2001 | 12:08 AM
86 IROC's Avatar
This is just my opinion, but I hear of people using mustang 19lb/hr injectors in modded 305's. Just a thought. Since most of those guys put #24's in their cars - you should have no trouble at all finding a cheap set of #19's. BTW - I believe I read somewhere that the #19's were good for up to 350 N/A HP.
1986 IROC, fully loaded, Mini Ram'd 383, Art Carr 700R4, Accel DFI, 12 bolt rear, etc, etc......
Old Sep 29, 2001 | 01:52 AM
Free Bird's Avatar
Car: 91 GTA and 85 IROC
Engine: 355
Transmission: gear jammer
Axle/Gears: 4.11
I'll second that. 350hp is the max HP that 19# can support.
Mods: ZZ4 engine w/stock TPI, adj, fuel pres. reg., MSD 8.5, HI6S ign. w/ PS-91 coil, K&N filter, TPI air foil, Hooker comp. shorties, American Thunder flows. 160* stat., TB bypass, 3"cowl, bat. relocate, AC delete, stock T-5 w/ 3.42 rear, ported plenum, 24# inj.
92projectcamaro
Jan 18, 2016 08:00 AM
toronto formula
Nov 10, 2015 06:17 AM
Brother Al
Oct 14, 2015 06:39 AM
BAMiller
Sep 14, 2015 06:38 PM
