modify TPI???
Old Sep 29, 2001 | 12:30 AM
Vomex's Avatar
modify TPI???
I know this may sound like a stupid question, but i dont know much about injection systems. I wanted to know what kind of stuff you can do to modify you TPI system. Other than porting your plenum and getting bigger injectors is there anything else you can do?
Later,
Vomex
'89 GTA 5.7L TPI
Old Sep 29, 2001 | 01:02 AM
IROC&ROLL
Guest
Posts: n/a
Porting the manifold base or buying a hi-flow base, buying a larger throttle body, buying better runners, throttle body coolant bypass. Those and the mods you mentioned won't do much without other mods (like cam, headers, catback, heads, etc.) that can take advantage of them.
Old Sep 29, 2001 | 02:13 AM
Kevin91Z's Avatar
Car: 1990 Pontiac Trans Am
Transmission: Tremec T56
Axle/Gears: 12-Bolt 3.73
Dont get bigger injectors on a stock engine, you dont need them.
Read the tech articles on this site, particularly the one entitled "Suggested Mods for Thirdgen TPI Engines".
Also check out the local SoCal Thirdgen club in my sig.
1991 Camaro Z28
5.7L 5-Speed (originally 305)
317 RWHP, 418 RWTQ
13.23 @ 107.62 MPH
Southern California
Member: SoCal 3rd Gen F-Bodies
Member: SoCal F-Bodies
-=ICON Motorsports=-
Frozer!!!
Jan 19, 2024 04:55 PM
Vintageracer
Jan 10, 2020 05:33 PM
evilstuie
Apr 14, 2016 08:52 PM
theurge
Aug 21, 2015 12:46 PM
Sanjay
Aug 12, 2015 03:41 PM
