what should i do next???? more within
Old Oct 4, 2001 | 09:02 PM
eddie89TA's Avatar
Car: 89GTA
Engine: 355TPI Edelbrock heads, base. SLP r
Transmission: TCI streetfighter 700r4
Axle/Gears: B/W3:27
i have a tci streetfighter tranny enroute to the house i was contemplating SLP runners, or maybe a msd6a ignition?, pulleys?my mods r listed in my sig. my goal is mid 13's is it possible? r the SLP runners worth while?
white/gold GTA ,leather new 5.7TPI ,S/R torker 2.02 1.60heads comp cam 212in 218ex dur. .475in .495ex lift. edelbrock headers ,dyno 2000 says 337 hp 405ft lbs of tork..700r4 3:27posi twin cats,3"catback,aluminum d.shaft ported plennum,afpr,8mmwires,k&Nand all other "free" mods, performance resource chip,SLP cold air intake.
Old Oct 5, 2001 | 12:35 PM
91'firebrd's Avatar
I'd either port or replace the manifold base. That will help with both the stock tubes or after market ones.
Then change your gear ratio to 3.7X's. That is a fun SOTP noticable mod. Then you take care of your traction problems you will have.
Low 13's is not out of the question.
