do i need a roller cam or flat tappet?
Old Apr 20, 2008 | 07:10 PM
billybird's Avatar
Car: 89 Formula
Engine: LB9 TPI
Axle/Gears: 3.73(coming soon)
hi guys im shoping around for a cam for my 89 formy 305 tpi and it shows both flat tappet and roller?..wich one is our cars?
Old Apr 20, 2008 | 08:44 PM
85irocz355tpi's Avatar
Car: 85 IROC-Z
Engine: 355 TPI
Transmission: 700R4w/Shift Kit
Axle/Gears: B/W 9 Bolt-3.45
Re: do i need a roller cam or flat tappet?
from 87-up all small blocks came from the factory with roller cams. But you can use a flat tappet cam in your car if you want. It's just harder to retrofit a roller cam in an 86-earlier sbc. I hope this helps and if you have any further questions let me know.
Old Apr 20, 2008 | 08:48 PM
billybird's Avatar
Car: 89 Formula
Engine: LB9 TPI
so you can put a flat tappet in with no problems i guess? thx for the info man
Old Apr 20, 2008 | 09:04 PM
85gulstrandTA's Avatar
Car: was 85 TA, 91 TA both sold
Engine: was 406, now 305 tpi
Transmission: 85 had700r4,350..91 had t5
Axle/Gears: 323,373,342
Yes you could use a flat tappet cam. BUT WHY ? If you already have the motor and all you need is a cam then get the roller cam, with a roller motor you can reuse the roller lifter. Roller cams make more power with less friction, which means more mpg and less wear. If you get the flat tappet cam you will need lifter also, and todays oils are known to wipe out the cam lobes on flat tappets.
You did not say why you needed a cam ? Do you just want more power ?
The 89 305 TPI with the 5 speed manual has a pretty fair cam...same as the 350 TPI's
Hotrodboba400
Dec 10, 2019 07:07 PM
Jorlain
Oct 8, 2015 01:57 AM
Nick McCardle
Sep 10, 2015 08:36 PM
Hotrodboba400
Sep 2, 2015 07:28 PM
