Question for guys who bought Junked TPI's and had to put it back together!
Basically im 2 days away from being complete with my project, as of now i have one delema, I need all sensors which are located on a TPI manifold, its from a 87' Motor but i bought a Edelbrock intake manifold. Could u possibly name all types of sensors that are located on Intake manifold for Tuned Port Injections. My mechanic and I are in need of help on this question, thanx
Car: 89 FORMULA 350, 91 Z28 Convertible
Engine: ls1, LB9
Transmission: t56, Auto
Axle/Gears: S60/ 3.73
go to the dealer and look at the parts screen for the manifold. you just asked a very vage question. I can only think of the temp sendors like air temp, coolant temp, egr pos sensor(should be with the egr)
Car: 1989 Camaro-1LE
Engine: TPI(s)
Transmission: 5 speed (MM5, MK6)
Axle/Gears: 3.45, 3.73
On the front,
- cold start injector temp sensor (the larger of the two)
- coolant temp sensor
On the top-middle:
- EGR valve
Driver'side
- cold start valve
Upper plennum - underneath
- MAT (manifold air temp)
Throttle body:
- TPS (throttle position sensor)
- IAC (idle air control valve)
Passenger side block
- knock sensor
Rear of block, or lower drivers side
- oil pressure / fuel cut off switch
Attached to a bracket on the intake
- EGR solenoid
That's about all I can remember.
Mark.
On the top-middle:
- EGR valve
Driver'side
- cold start valve
Throttle body:
- knock sensor
- EGR solenoid
Mark.
In manifold:
Mass Air Flow Sensor or Manifold Air Pressure Sensor
(Depending what computer you have)
Coolant Temp Sensor & Mass Air Temp (same part number)
Throttle Position Sensor
Idle Air Control
Elsewhere:
Oxygen Sensor
Knock Sensor
Oil Pressure Sensor
[This message has been edited by u r sofa king we tah did (edited October 09, 2001).]
Idle Air Control
Elsewhere:
Oxygen Sensor
Knock Sensor
Oil Pressure Sensor
84z96L31vortec
Aug 20, 2017 12:16 AM
86IROC112
Aug 17, 2015 02:00 PM
84z96L31vortec
Aug 10, 2015 08:27 PM
