12.3 @ 111 with long tube runner setup in CHP??
Old Oct 16, 2001 | 06:14 AM
ImportsRsloths's Avatar
How come no one on here is close to that???? There isnt even that many mods on that car. They could get that into the 11's.
Old Oct 16, 2001 | 07:10 AM
Ed Maher's Avatar
Car: 04 GTO
Transmission: M12 T56
I haven't seen that article, but what do you mean noone here is close to that. Trax has run 12.2@112 w/ his mild miniram set-up, his new set-up will easily be 11s. Even when it had an AS&M runner set-up it was running 12.6 or .8 @ 108. And we're talking a full weight car w/ stock shortblock and tranny. And there are a bunch of other people that fast around here too.
Old Oct 16, 2001 | 10:16 AM
camaro6spd's Avatar
note---he said long tube runner, not miniram or SR or RJ. just clearing that up :0
Old Oct 16, 2001 | 10:49 AM
88 IROC BOB's Avatar
note--Ed just said that Trax went 12.8 with LTR's. He also had AFR heads and a nice comp cam. So yes mid 12's are possible with LTR's!
Bob
350 TPI, 700R4(rebuilt), K&N's, MSD 6AL, Headers, Flowmaster, 160* stat, airfoil, MAF screens cut out. 13.88 @ 101.18 mph
Old Oct 16, 2001 | 11:17 AM
TPI Guy's Avatar
Car: 1968 Camaro
Engine: 406
Transmission: Tremec TKO
I think that people are getting way too caught up in times and are overlooking Trap speeds. ET's are not indicative of horsepower. As a rough estimate, if you have 320 rear wheel horse and a 3600 lb. car you can run a 12.99. But your MPH will be fixed. You must have a MPH of better than 104 to run a 12.99 Your ET potential cannot exceed Power indicated by the MPH (This is for the new guys as I can see many of you are aware of this).
For a 12.3@111, you need to have a near perfect traction. Also, was the CHP time and MPH corrected for altitude?
355 c.i.
Dart 180 Heads
Lunati 224/224 cam
Harland Sharp 1.5 rockers
Performer RPM Manifold
Holley 600 cfm double pumper
Hooker Super Competition Headers
Flowmaster Exhaust
Competition Engineering Sub-frame connectors
Super T-10
GM posi 3.42 rear
Hurst Roll Control
13.9@102
Old Oct 16, 2001 | 12:20 PM
Killer-Z's Avatar
<font face="Verdana, Arial" size="2">Originally posted by TPI Guy:
</font>
Very valid points!!! Later Derrick
Old Oct 16, 2001 | 02:25 PM
Crusader's Avatar
Car: 1988 Firebird Formula
Axle/Gears: 3.45
...You must have a MPH of better than 104 to run a 12.99 ...
</font>
So the Formula Popular Mechanics ran to a 13.15 sec. @ 108.27 mph should be capable of 12's?
Old Oct 16, 2001 | 02:42 PM
TPI Guy's Avatar
Car: 1968 Camaro
Engine: 406
Yes, with the suspension and drivetrain optimized with a good driver. Traxion ran 12.8 @108.
Old Oct 16, 2001 | 02:49 PM
GregWestphal's Avatar
Car: '87 Camaro IROC-Z
Engine: 385 HSR
Axle/Gears: 3.42 posi
Actually, I think he ran a 12.5 at 108 mph with the AS&M semi-siamesed runners, ported plenum, AFR heads, and 218/224 cam. I was there when he ran a 12.2 at 112 mph with the Mini-Ram and front skinnies.
Greg Westphal
'87 IROC 355TPI/A4
Old Oct 16, 2001 | 04:10 PM
Acceld Z's Avatar
Car: 1992 Z28
Engine: 355
Ed if you want to see the article just go look in the magazine articles on this site. The new article is a redo of the "Hardrock Camaro" article. If you'd like to see the new article I can e-mail it to you. Anytime I see that 1 company (TPIS) has provided most of the upgrade parts for a mag article I generally conclude that the #'s have been "corrected" Especially when that company is TPIS.
92Z28
89GTA
[This message has been edited by Acceld Z (edited October 16, 2001).]
Old Oct 16, 2001 | 04:39 PM
91-ZZ4-Z28's Avatar
I know of a car running 12.1 on LPR's. That is the best but I have seen several in the mid 12 range.
1991 Z28 ZZ4 with LPE superram base, SLP runners, LPE 58mm T-body,Random Technology ramair,TES headers,24#svo injectors,ZEX nitrous,Walbro 255lph f-pump,Accel AFPR,Random Technology catback,!cats,and mutch more.
Old Oct 16, 2001 | 08:15 PM
aziroc's Avatar
Car: 86 IROC-Z
Engine: 406
well, i may not count, but my 406 has TPIS runners, intake, and a58mm t.b. the engine itself is suppose to rev up to 6200, but all the power is going to be at 5500 rpms. heck, 300lbs tq at 1500 rpms.. im waiting to turn sideways on a launch.
Old Oct 16, 2001 | 11:24 PM
BadSS's Avatar
</font>
Be careful when you say cannot. There are plenty of bracket cars around the country whose “formulated” HP from the ET exceeds the “formulated” HP from the speed. However, I will agree 100% that you can use the HP numbers derived from speed to see if you have potential for increasing the ET.
To address the orignal post concerning the 12.3 CHP article,, check these links out.
https://www.thirdgen.org/messgboard/...ML/003088.html
https://www.thirdgen.org/messgboard/...ML/003913.html
https://www.thirdgen.org/messgboard/...ML/001533.html
Old Oct 17, 2001 | 09:45 AM
BadSS's Avatar
Double post
[This message has been edited by BadSS (edited October 17, 2001).]
Frozer!!!
Jan 19, 2024 04:55 PM
87iroctheo
Dec 4, 2016 11:47 AM
formula_novice
Sep 5, 2015 03:58 AM
beast94
Aug 20, 2015 06:44 AM
