A little help...Is it the speed limiter or what??
Old Apr 30, 2008 | 09:23 PM
WhiteIrocZ's Avatar
Car: 87 Iroc Z
I have recently changed the gear from a 2.73 to a 3.42. I haven't got a chance to change the speedo gear so it reads very high compared to my actual speed. I got on it a little tonight and when the speedometer got to around 110, the car felt like I was letting off and stomping it very rapidly. Is this the speed limiter? Also, the car will not shift into overdrive at full throttle, how do I make it. If I ever decide to run the 1/4 mile, I'm probably going to need it because I already trapped 81 mph in the 1/8th mile with the 2.73 gear so I will trap higher in the 1/4 than the car is capable of right now. BTW, does anyone know right off hand what speedo gears I need for the sensor in order to correct the speedometer.
Old May 1, 2008 | 02:50 PM
jv9999's Avatar
Car: '87 IROC/'68 SS
Engine: 5.7L/350
Transmission: 700R4/Muncie 4-spd
Axle/Gears: 3.27 9 bolt / 3.31 12 bolt
Re: A little help...Is it the speed limiter or what??
Try this: http://web.archive.org/web/200602060...net/speedo.htm
RedLeader289
Sep 23, 2015 06:50 AM
adelane
Sep 9, 2015 08:51 PM
SG91camaro
Sep 5, 2015 10:27 PM
UltRoadWarrior9
Sep 2, 2015 08:24 PM
FLAP
Camaros Wanted
Sep 2, 2015 09:22 AM
