march pulleys
Old Oct 16, 2001 | 09:38 AM
palric's Avatar
Car: 90 IROC 5.7 hardtop
Transmission: T5 swap
Axle/Gears: Yup -- they still work
march pulleys
Has anyone tried these pulleys (crank and alternator) on an LB9 TPI car ?
Are they a waste of time or has anyone actually seen some performance from installing these ? Just wondering if it is worth the $100 and an after-noon's work ?
Thx, RP.
'91 Formula Firebird G92,WS6,5-speed,3.42 a ton of fun to drive.
Old Oct 16, 2001 | 11:04 PM
KNTA4DNU's Avatar
Car: '97 Z28
Engine: 5.7
Transmission: M6
Like a lot of other bolt on mods, I think they do make a slight difference. I can't pinpoint any particular mod that helped the most, but together they add up to a noticable increase in power.
I'm wondering though if anyone had the same problems that I experienced with the pulleys?The powdercoat finish immediately started to peel off. I also had a terrible squeal (not slipping) that was finaly solved, by suggestion of a heating/air conditioning engineer, with the installation of a wider power steering belt that runs higher in the pulley and stopped the noise.
87 Formula 305TPI T5
Cat Back, Underdrive Pulleys, AFPR, Chip, Etc.
Old Oct 19, 2001 | 10:07 AM
Drkhrse89's Avatar
Car: 89 Iroc
Engine: 305TPI
I have the pulleys on my 305 but didnt notice any huge difference but that was because I threw on a bunch of other stuff at the same time. They are not going to net you 10hp or anything like that but it is just one of those things that you throw on with a bunch of other little things and you will make your car faster.
Thirdgen89GTA
Nov 26, 2015 11:04 PM
bigjay89gta
Oct 15, 2015 08:04 AM
jaridjohn
Oct 5, 2015 07:01 AM
anesthes
Sep 30, 2015 07:48 AM
JSDaddy189
Sep 26, 2015 03:50 PM
