Intake tubing
Intake tubing
Does any body make a larger piece to go over the front of your throttle body? It's just a pain in the *** to put that thing back on.
88 Formula 350
Upper and Lower SuperRam, 1000 CFM Accel Throttle Body, 24# Motorsport Injectors, Custom Burned PROM, Larger Gutted Mass Sensor, MSD 6a box, Flowmaster Muffler, Homemade Cold Air induction, TB Bypass, B&M shift Kit, 160* Thermostat, ZZ4 cam, MSD Distributor, Accel SuperCoil, Taylor 8mm wires,
88 Formula 350
try some lubrication
- David
88' GTA 5.7L TPI MODS---> air foil, K&N, Shift Kit, 180* therm, TB bypass, Gutted CAT, Flowmaster 80 Series
http://www.geocities.com/david_angel_16
- David
Car: 1991 Firebird
Engine: 427 LSX
Transmission: Turbo 400
JR444, what does your car run?
1991 Firebird
350 L98 (was a 305 TBI),T-5,Edelbrock TES and cat back,Accel manifold
NOS,subframes,jegster torque arm,MSD Digital 6
AFPR,Lakewood lcas
Hurst linelock,SLP cam (206 212 .480 .486),relocated battery,cold air,Hypertech chip,centerforce df,clutch
poly bushings and mounts
AFR 190s
Harland sharp 1.5 rockers
autopower rollbar
12.33 @ 114.83 juiced uncorrected
13.510 @ 102 non juiced uncorrected
1991 Firebird
AFPR,Lakewood lcas
AFR 190s
autopower rollbar
GofasterFirebird, I'm taking it to the track next Saturday, and I'll post the times then. I asked the people on this board what they thought I'd run and they said like a low 14 to high 13; I'll just have to wait a week and find out.
88 Formula 350
Upper and Lower SuperRam, 1000 CFM Accel Throttle Body, ZZ4 cam, 24# Motorsport Injectors, Larger Gutted Mass Sensor, Homemade Cold Air induction, Custom Burned PROM, MSD 6a box, MSD Distributor, Accel SuperCoil, Taylor 8mm wires, TB Bypass, B&M shift Kit, 160* Thermostat, Flowmaster Muffler,
88 Formula 350
toronto formula
Sep 10, 2015 07:31 AM
