Did all 350's get posi ??
Old Oct 27, 2001 | 08:15 PM
91Z28's Avatar
Car: 91' Z28
Engine: 355-Supercharged
The reason i ask is i did a burnout the other day, and only left one mark on the pass side ??
Also one non related Q, when i put the key in the ignition "INFL REST" comes on and then goes off, what does that mean ??
Old Oct 27, 2001 | 11:04 PM
91z4me's Avatar
INF REST means your computer is checking to see that your air bag is working I think. I also think you may have a limited slip diff. Don't know the difference but I think that was the rear end.
91 z-28 305 700R4
3.73 gears out back
T-Tops and Black all over.
Old Oct 28, 2001 | 12:49 AM
okfoz's Avatar
Engine: 5.1L TPI, 5.0L TPI
Transmission: 700R4, M5
It is entirely possible for a person ordering a car to delete the Limited Slip Axel. Got a buddy that did it to a brand new T/A a few years back for one reason. To BURN rubber. He was not interested in low ET's but leaving a long black layer of rubber down the road.
It was his car.
In short: I would guess 95%-99% of all 350s have the limited slip, but not all.
I also happen to know that my limited slip axel likes to spin the right rear wheel. It IS Limited slip, cause...I installed it.
John
Old Oct 28, 2001 | 01:07 AM
RODS92Z's Avatar
The airbag light is suppose to come on when you turn the ignition on and shut off. If it stays on then there is a problem with the airbag. I have never come across a 350 with out posi. But I suppose its possible.
Old Oct 28, 2001 | 02:15 AM
91Z28's Avatar
Car: 91' Z28
Thank you all for your reply's, can somone explain limited slip ? how does it work ?
Old Oct 28, 2001 | 10:01 PM
smokin87iroc's Avatar
Car: 87 IROC
Engine: 305 TPI going to LT1
Transmission: 5spd
limited slip is supposed to act like positraction when both weels get similar traction.
when you take a turn it will open up and act like a "open" differential to let the inside tire to turn slower than the outside tire to reduce tire wear and stress on the rear diff.
to tell if you have limited slip or open differential jack your car up at the rear and turn one wheel with your hand. if the other wheel turns the same way you have limited slip. if it turns the opposite way you have a true open differential
Andrew
IROCZDAVE (88-L98)
Nov 19, 2015 07:03 AM
angel2794
Sep 8, 2015 06:22 PM
Hotrodboba400
Sep 2, 2015 07:28 PM
Eric-86sc
Aug 24, 2015 09:01 PM
neekolzun
Aug 24, 2015 04:59 PM
