Differences between Accel/Lingenfelter runners....
Old Oct 28, 2001 | 07:51 PM
zedder 1 9 9 0's Avatar
Car: 1990 Iroc Z Convertible
Engine: LB9
I picked up a used set of these runners for a good price not realizing that there were 2 different kinds made. I believe these were from a 1987 Iroc and I have a 1990 LB9.My next generation catalogue lists 2 types of these TPI runners 85-88 and 89-92. Does anyone know the difference? Actually Slp and Edelbrock also list different runners for these same years. Its not a speed density issue because 1989 had maf.Damn I hope I can use these.
1990 Iroc convertible,305 tpi,Black with black leather interior,lowered,Taylor 8mm wires,K&N's,gutted airbox
Old Oct 28, 2001 | 08:15 PM
rezinn's Avatar
You can use them, I don't think you will have any problems. There may be a hole in the drivers side runner for the cold start injector, but that shouldn't cause any problems. I was using the 1990+ runners on my 87 camaro for a while, I don't need the cold start injector in california.
Old Oct 28, 2001 | 10:42 PM
Kevin91Z's Avatar
Car: 1990 Pontiac Trans Am
Transmission: Tremec T56
Axle/Gears: 12-Bolt 3.73
To use 85-88 runners on an 89-92 car, you'll need to plug up the driver's side small tube with silicon, to prevent vacuum leaks. The difference between 85-88 and 89-92 is the cold start injector. 89-92 doesnt have it.
1991 Camaro Z28
5.7L 5-Speed (originally 305)
317 RWHP, 418 RWTQ
13.23 @ 107.62 MPH
Southern California
Member: SoCal 3rd Gen F-Bodies
Member: SoCal F-Bodies
-=ICON Motorsports=-
69GTOby
Apr 18, 2016 02:34 PM
BAMiller
Sep 14, 2015 06:38 PM
Numbah-1
Sep 12, 2015 08:57 PM
J.C. Denton
Sep 8, 2015 05:35 PM
greenyone
Sep 2, 2015 03:39 PM
