timing questions/ smog question in ca
Old May 13, 2008 | 07:37 PM
dspencer24's Avatar
Car: 91 z28
Engine: 350/ported accel tpi/AFR 195
Transmission: t-5 =(
Axle/Gears: 345
whats the base timing supposed to be set on an lb9? it was at 8* and it was surging and the car seemed to have a miss? So i turned it down and poof it was gone and it runs good now i heard you have to have it set at 8* for smog in ca is this true?
Old May 13, 2008 | 08:14 PM
Frank 84 Bird's Avatar
Car: 87 Trans Am
Transmission: TKO 600
Re: timing questions/ smog question in ca
I believe it should be 6* + or - 1* otherwise they can fail you.
Old May 14, 2008 | 12:07 AM
dspencer24's Avatar
Car: 91 z28
Axle/Gears: 345
hmm whats do you guys have your timing set to?
Old May 14, 2008 | 08:32 PM
dspencer24's Avatar
Car: 91 z28
Axle/Gears: 345
could it be possible to have my dampner is off or could my tdc be off?my timing is at zero and i set my iac to and now my car is sounding better and runing better then ever? its not as responsive but it runs better. and my idle is perfect now
Old May 14, 2008 | 08:38 PM
vasquezmrysvll's Avatar
Car: 1985 California Iroc
Engine: HSR ZZ4 0411 swapped
Axle/Gears: 3.23 posi
sorry for hyjacking your thread, but when i flash my timing light...i cant see the groove on my dampner anywhere? tdc off? it runs but is EXTREMLY hard to tune due to me not being able to time it?
Old May 14, 2008 | 08:48 PM
dspencer24's Avatar
Car: 91 z28
Axle/Gears: 345
did you unplug the est? if not do so its a lil brown conector located on the passeger side of the engine bay
Old May 14, 2008 | 09:06 PM
yah, and i still cant see the line on my balancer? i even painted the line white when i had the engine out?
Old May 14, 2008 | 09:57 PM
dspencer24's Avatar
Car: 91 z28
Axle/Gears: 345
are you on the right plug? front of engine on driver side?
Old May 14, 2008 | 10:11 PM
yes, im on the #1. im following all the proper procedures.
Old May 15, 2008 | 10:38 PM
dspencer24's Avatar
Car: 91 z28
Axle/Gears: 345
anyone?
Old May 16, 2008 | 12:30 AM
Kevin91Z's Avatar
Car: 1990 Pontiac Trans Am
Transmission: Tremec T56
Axle/Gears: 12-Bolt 3.73
A TPI setup, 305 or 350, should be 6 degrees stock. You are allowed plus or minus 3 degrees. Anywhere from 3 degrees to 9 degrees is good to pass smog. 6-8 would be the best, that way you have one degree of cushion in case the tech's timing light is off. Less than six would give you less power and we dont want that.
Old May 16, 2008 | 01:37 AM
85IrocZ-28's Avatar
Car: 1985 Iroc Z-28
I have always had this timing problem. I actually set it about three years ago at a shop while I was watching how clean it was running on their scanner. Even when I unplug the timing wire, I can't see the line on the dampner.
I was told that my dampner may have spun on itself, but this wasn't the case. I did this on my old motor, and also with the brand new dampner I installed on the new motor. I was also told it could be my computer, but I have since replaced it and still have the same problem with not being able to time it. I don't have an answer for you, just thought that I would mention I also had this problem. Hopefully someone will have an answer.
Old May 16, 2008 | 08:12 AM
iv also been told that the dampner could have spun on its self? its new?
Old May 16, 2008 | 03:16 PM
dspencer24's Avatar
Car: 91 z28
Axle/Gears: 345
i thats what i heard as well thanks for your response i wonder why my car is runnning so well at 0
Old May 18, 2008 | 12:14 PM
Kevin91Z's Avatar
There are two different kinds of dampners. One kind has the zero mark straight up, and that's used on carb and TBI cars. The TPI kind has the zero mark at the 2 o'clock position. If you have the wrong balancer, your timing will be all messed up and your car will not run correctly.
Old May 19, 2008 | 12:11 PM
85IrocZ-28's Avatar
Car: 1985 Iroc Z-28
Kevin, This makes more sense than anything else I have ever thought of...I have just been setting the timing to run smooth and clean while hooked up to an emissions testing machine. The dampner that was on the car when I bought it was like this, and the replacement was the same. I will have to get the right one in the future...
ezobens
Aug 19, 2015 10:29 PM
redmaroz
Aug 16, 2015 11:40 PM
jackhammer
Aug 15, 2015 10:04 PM
Feffman
Mid-West Region
Aug 13, 2015 07:12 AM
Feffman
Aug 13, 2015 07:11 AM
