which is better?!
Old Nov 3, 2001 | 09:35 PM
89Irocz23's Avatar
which is better?!
I have a 89 Iroc Z. SO it has that good faction set up with an easy way to get ram air through fog lights. What is better using that set up with k&n with ram air or building my own custom cold air intake with the k&n cone filter?
Old Nov 3, 2001 | 10:05 PM
rezinn's Avatar
The fog light one is cheaper, and it would probably help more at higher speeds than the cold air. That is just my opinion though.
Old Nov 3, 2001 | 10:14 PM
anesthes's Avatar
TGO Supporter/Moderator
Car: '88 Formula
Engine: LC9
Axle/Gears: 3.89 9"
Hey,
You should prolly pickup an air foil. You might actually have problems at higher speeds w/out one.
-- Joe
Old Nov 3, 2001 | 10:56 PM
89Irocz23's Avatar
ya I am planning on getting one, but first I havent decided on if I want to go through the fog lights or a cold air one instead.
Old Nov 4, 2001 | 08:34 AM
89Irocz23's Avatar
btt
Old Nov 4, 2001 | 01:08 PM
89Irocz23's Avatar
im not worried about high speeds for the ram air. What a cold air intake be better for driving about 0-60? i dont normaly drive at high speeds so.
Old Nov 4, 2001 | 03:07 PM
anesthes's Avatar
Car: '88 Formula
Engine: LC9
Axle/Gears: 3.89 9"
It really depends on the motor. Cooler
are is more dense, you'll get more of it in the motor. But running lean is no good either.
I have big injectors, and big heads so more air through myu crappy throttle body helps a lot.
The Mustang 5.0 people always claim that the cold air was "the best thing they ever bought"
-- Joe
