Miniram vs. LT-1
Old Nov 5, 2001 | 07:19 AM
BryanJ's Avatar
Miniram vs. LT-1
which of these would be a better induction? I was planning of visiting a junkyard and seeing if I could find an LT-1 intake and try to send it off to be extrude honed. Which would be better, if its worth the extra money I will get the miniram.
Thanks,
Bryan
Old Nov 5, 2001 | 07:34 AM
Kevin G's Avatar
You really do not need to extrude hone an LT1 intake.. The stock opening of the intake for the TB is 52 mm... All you really need to do is to gasket match the intake ports to your setup if needed and boring the TB openings to 58mm depending on which TB you use ..The LT1 intake can handle a ton of h.p. before becoming a restriction. Now on that note, I guess your thinking about doing John Ms conversion on a non LT1 engine right? Because it wont work right up on a normal SBC motor.
[This message has been edited by Kevin G (edited November 05, 2001).]
Old Nov 5, 2001 | 10:04 AM
nice3rdgenz's Avatar
i like the mini ram myself...
91z28 350tpi auto, runs 14.3... aim screen name nice3rdgenz
http://www.fbody.com/members/nice3rdgenz/index.htm
Old Nov 5, 2001 | 10:14 AM
rockind78's Avatar
Kind of beside the point I know, but I thought LT-1 throttle bodies were 48 mm. Did GM go to a 52 when they went to LT-1? Just wondering.
Old Nov 5, 2001 | 10:19 AM
Kevin G's Avatar
Sorry, Rockind78, my last post was confusing, so I did a minor edit to it.. Thanks for pointing it out.
Yep, the throttle bodys are 48mm with the LT1, but the machined openings on the LT1 intake are 52 mm. So if you upgraded to a 52mm TB, there is no need for machine work on the openings. You would only need to open them up more if you went with a 58mm.
Old Nov 5, 2001 | 03:29 PM
BryanJ's Avatar
what about the LT4 intake, I think I'm gonna start with the bowtie block and I should get it next week.
Old Nov 5, 2001 | 09:33 PM
rockind78's Avatar
Ahhh. I see. Thanks.
gixxer92
Apr 12, 2022 12:09 AM
88SS6SPEED
Nov 11, 2015 07:05 AM
92rsvortec350
19
Oct 9, 2015 09:39 AM
BWilcox
Sep 20, 2015 12:19 PM
3.8TransAM
Sep 17, 2015 02:16 PM
