need help
Old May 18, 2008 | 10:38 AM
89IROKCONVERT's Avatar
need help
Ok i have an 89 iroc i was rebuilding the motor after installing a manual trans when the shop i was working in burned down taking my motor trans and all wiring so i bought a whole new car thinking it was the same a 92 camaro (i drove 2.5 hours to get an maf sensor and spent too much time looking for the wire to the map sensor) so now I'm having problems getting it to run right first problem - my chiltons tells me how to adjust the tps then tells me to see attached photo but there is no photo so i don't know which terminal is a b or c i assumed top was a but the readings i get aren't even close to what i'm supposed to see second problem- my air temp sensor wire is nowhere to be found so i assume it was part of the emission controls how do i bypass that ? third problem it seems to be overheating very quickly and will barely run which i hope is caused by the other 2 problems
Any help would be appreciated
