Tuning Fuel Pressure w/ O2 sensor?
Old May 21, 2008 | 04:14 PM
trueburton's Avatar
Car: '88 Red Trans Am w/ T-tops
I tried to do what the tech article explained on tuning fuel pressure w/ the O2 sensor but had some problems. The reading was way too erratic and jumped all over the place on my DVM. Why would this be?
Thanks. Adam
Old May 21, 2008 | 09:37 PM
ZZ28ZZ's Avatar
Car: 82 Z-28
Engine: 383 TPI
Re: Tuning Fuel Pressure w/ O2 sensor?
A narrow band O2 sensor, like the one installed in your eng, will only tell you if you're above or below 14.7:1 air/fuel ratio.
If it's reading .45v or below it's leaner than 14.7:1. It it reads over .45v, you're running richer than 14.7:1. The ecm is constantly correcting the mixture based on readings from the O2 sensor. That's why the readings are all over the place. It's either a little too rich or a little too lean all the time when in closed loop mode. If all is well, the AVERAGE mixture will be 14.7:1...
The amount the voltage varies from .45v is not a good indicator of actual mixture.
You need a wide band O2 sensor to get accurate readings on your mixture, especially as you move away from 14.7:1, like under hard acceleration where it should be richer.
Old May 21, 2008 | 09:54 PM
irocuroc's Avatar
Car: 89 iroc
Engine: l98
Transmission: tremec
Thanks. Adam
you are all over the place because the o2 is picking up lean or rich cyl from a leaky or weak injector.. get a scan tool and see what the blm's are. a balanced set of injectors will read about 128 left and right. You need level readings first then you can tweek fuel pressure using the o2.. lower numbers would indicate a lean engine, higher would be rich. adjust the fuel pressure till the blm's are at that 128.
Old May 27, 2008 | 04:30 PM
trueburton's Avatar
What are BLM's and what kind of scanner do i need?
db057
Jan 10, 2020 08:55 PM
meeklay812
Oct 1, 2015 03:46 PM
dusterbd
Sep 29, 2015 08:40 AM
m00n420
Sep 11, 2015 02:39 PM
