upper plenum!?
Old May 24, 2008 | 07:28 PM
speedlimit96's Avatar
Car: 92 25th anniversary z28!!
Engine: 5.7L 350
Transmission: 700R
Axle/Gears: stock
upper plenum!?
i am putting on new edelbrock high flow headers and intake manifold and i would like to put on a performance plenum but am having trouble finding any!! any suggestions would be great thanks!! also i am having trouble taking off the fuel rail and injectors its acting like it is stuck any suggestions?
Old May 24, 2008 | 09:07 PM
vetteoz's Avatar
Car: 82 Z28
Engine: 383 SP EFI/ 4150 TB
Transmission: T400
Axle/Gears: QP 9" 3.73
Re: upper plenum!?
You either buy a modified stock one ($$$)
http://www.corvetteplenum.com/
or spend a couple of hours with a die grinder for free as most do.
Old May 25, 2008 | 09:42 AM
Viprklr's Avatar
Car: 92 GTA/ 00 TA
Engine: 383/350
Transmission: 700R4/T-56
Re: upper plenum!?
I've never heard of an aftermarket plenum for our cars. Either port what you have or send it out. You could also have one custom made. Depends on how much money you have to burn.
There are 5 bolts holding the fuel rail to the manifold. 4 hold the rail and 1 holds the input/output tubes at the front of the manifold. If all 5 are out then go ahead and start prying. The injectors get stuck after years of being there.
sheachopper
Jul 31, 2019 11:27 AM
Ed1LE
Sep 30, 2018 09:14 AM
MrPackstin
Oct 25, 2017 08:09 PM
dbrochard
Interior Parts Wanted
Sep 28, 2015 07:40 PM
