What would this do? Intake parts "?"
Car: 91 GTA and 85 IROC
Engine: 355
Transmission: gear jammer
Axle/Gears: 4.11
I was going to put some SLP runners on my TPI ZZ4 w/ a 58mm TB. I want to run mid to low 12's at the track. How much of an improvement can I expect on the dyno and or track if I simese the runners and intake base?
Right now I run a 13.54 @102.8X. Dynoed at 257 hp and 356 tq.
I got the low end but it stops pulling at about 4500rpms.
PS- I'm trying to keep the same cam and heads.
Mods: ZZ4 engine w/stock TPI, adj, fuel pres. reg., MSD 8.5, HI6S ign. w/ PS-91 coil, K&N filter, TPI air foil, Hooker comp. shorties, American Thunder flows. 160* stat., TB bypass, 3"cowl, bat. relocate, AC delete, smog delet, cats gutted, stock T-5 w/ 3.42 rear, ported plenum, 24# inj., dual friction centerforce.
Car: 2018 Camaro SS
Engine: LT1 w/Paxton 1500SL
you'll notice a nice gain with the runners, now i'm no expert but i doubt u'll hit low 12's with those L98 heads and ZZ4 cam, i'm sure somone can chime in here with more info
*89 Trans Am GTA
*Moderator at www.transamgta.com
To hell with the GM vs Ford war. We must unite, as brothers to fight the plague that is overtaking the world...RICE
Tony
*89 Trans Am GTA
Tony
I'd say a 58mm TB is too big, buy a 52mm TB. Try some 1.6 ratio roller rockers and a high flow base manifold too. Low 12's will be almost impossible w/o a power adder. What do your 60 ft. times look like? Pull a wickedly fast 60 ft. time and you may get close to your goals. Good luck.
1986 IROC, fully loaded, Mini Ram'd 383, Art Carr 700R4, Accel DFI, 12 bolt rear, etc, etc......
Engine: 355
Axle/Gears: 4.11
My 60' is a best of 1.93. I was thinking more of a mid 12 and spray into the 11's. Right now I got stock suspension and street tires. I don't have just L98 heads and ZZ4 cam, I got the complete long block w/ a stock TPI setup on it.
More importantly I just want to run a 12. I don't care what kind of 12, high or low. I'm still running they stock 305 chip in my car so I think that I could use a lot of tuning.
1992 Trans Am
May 10, 2023 07:19 PM
