what size it plenum bolt?
Old Nov 26, 2001 | 08:56 PM
breathment's Avatar
I lost the plenum bolt a while back, and at the time i didn't think it was causing a vacuum leak, but now my milage is going down, and i need to get a new bolt, i went to Home Depot, and non of their bolts would fit, wut size is are the bolts on the upper plenum? and how long are they?
edit: oops that should be what size IS plenum bolt, don't wanna make people think im more stupid then i really am
- David
88' GTA 5.7L TPI MODS---> air foil, K&N, Shift Kit, 180* therm, TB bypass, Gutted CAT, Flowmaster 80 Series Muffler added to Unkown CatBack, Ported Intake
http://www.geocities.com/david_angel_16
[This message has been edited by breathment (edited November 26, 2001).]
Old Nov 27, 2001 | 01:10 AM
Dyno Don's Avatar
Transmission: Tremec T-56
Axle/Gears: 12 Bolt 3.73
It's 8mm 1.5 the lengths vary.
Chronologically challenged. But still kicking!
'92 CAMARO RS
305 TBI 5/spd (now TPI)
B4C Alt.
Cam change:TRW 198/210 ,450/.460 114 LSA
Stock TBI manifolds
'85 IROC 3" Cat. back Exhaust
14.94-92.00 mph
SDPC base and "350" Vortec coming soon!
'69 camaro-BB/Lenco,1050 dominators, /Pump Gas/no drugs 8.97-150+/3200lbs.
SoCal Thirdgen F-Bodies
Old Nov 27, 2001 | 07:00 AM
GregWestphal's Avatar
Car: '87 Camaro IROC-Z
Engine: 385 HSR
Axle/Gears: 3.42 posi
The top plenum bolts are M8X1.25 and are about 40mm long, maybe 35mm.
Greg Westphal
'87 IROC 355TPI/A4
toronto formula
Nov 10, 2015 06:17 AM
gixxer92
Sep 1, 2015 04:32 PM
Hawkeye1980
Aug 31, 2015 07:09 AM
355tpipickup
Alternative Port EFI Intakes
Aug 22, 2015 06:06 PM
knight72
Aug 10, 2015 09:32 PM
