What year did they change to speed density?
Hi,
Im pickin up a fuel injection setup of a 89, or 90 car not sure. What year did they change to speed density? Also are there anythings I should look out for?
Car: 2018 Camaro SS
Engine: LT1 w/Paxton 1500SL
they changed over to speed density in 1990
*89 Trans Am GTA
*Moderator at www.transamgta.com
To hell with the GM vs Ford war. We must unite, as brothers to fight the plague that is overtaking the world...RICE
Tony
*89 Trans Am GTA
Tony
the got rid of the cold start valve in 89. just to let ya know. if that matters in ur case
- David
88' GTA 5.7L TPI MODS---> air foil, K&N, Shift Kit, 180* therm, TB bypass, Gutted CAT, Flowmaster 80 Series Muffler added to Unkown CatBack, Ported Intake
http://www.geocities.com/david_angel_16
- David
Car: Death Mobile
Engine: 666 c.i.
If you plan to run TPI fuel injection, you must get the ECM, which also controls the distributor. You can tell if the TPI is a SD setup by looking at the back "passenger side" of the plenum for the spot that the MAP sensor bolts and connects to.
colton_carlson
Mar 8, 2019 12:21 PM
