I have a little problem on a 88 iroc I just bought
Car: 1988 IROC-Z
Engine: 383 HSR
Transmission: 4 speed Automatic
Axle/Gears: 4:10
I just bought a 88 iroc-z with a 350 tpi. I am having trouble to start it in the morning, it takes 3 to 4 seconds to start. the motor is the original with 134k miles on it. Everything is stock, and I was surprised of the power it has when I floor the pedal and it has no trouble spinning the tires even tough it has a 2.77 gear ratio, so , I almost discarded the posibility that may be low compresion on the cylinders. Has anyone had this kind of trouble before? Could it be a mechanical or electrical problem? thanks
Car: 2018 Camaro SS
Engine: LT1 w/Paxton 1500SL
how hard is the car to start after driving it for a while? example:say u drive it around then stop to get gas or run into the store for something, does it still take 3 or 4 seconds to start it then?
*89 Trans Am GTA
*Moderator at www.transamgta.com
To hell with the GM vs Ford war. We must unite, as brothers to fight the plague that is overtaking the world...RICE
Tony
*89 Trans Am GTA
Tony
Car: '89 TA
Engine: LB9
Transmission: M5
If its only in the morning I wouldn't worry too much about it. Mine takes about as long when its been sitting all night, and slighty more cranking time is needed overall during the winter. Seems to be the same for all the 8-cylinder f-bods I've seen
Just my opinion
http://www.tcnj.edu/~esposit3
https://www.thirdgen.org/rides/index...ew&rideid=1137
Member of FBS
AOL IM Name: JimmyTime5
Just my opinion
Member of FBS
- '89 Trans AM, 305 TPI, 5-spd
- '86 Firebird, 2.8, Auto
86IROC112
Sep 7, 2015 01:37 PM
92camaroJoe
Aug 13, 2015 06:07 AM
mustangman65_79
Aug 11, 2015 03:17 PM
