how low can the fuel pressure be to still run car?
Old Jun 10, 2008 | 10:10 PM
Bobby_80s's Avatar
Car: 1987 Camaro, 1986 Trans AM
Engine: V6 2.8 multi-port and V8 5.0 FI
Transmission: 5-Speed and Automatic
Axle/Gears: no idea
i had a digital fuel pressure gauge hooked up in my car
within two weeks it just scrolls low
the company sent me a new sender i havent installed it yet
i have a high idle and one day got a code 44, it went away
still high idle
dont give all the iac tps suggestions
im just trying to rule out my fuel pump
iac is new
tps is .54v
rebuilt maf
fresh ford 19lb injectors
car has always idled high just now its worse and im still in the troubleshooting process
ill be able to datalog soon
im just trying to get smarter and feed my curiosity for the time being
the fuel sender will scroll low if the pressure is below certain psi
either the sender went bad withing two weeks or maybe just mayeb the fuel pump is going or my year old fuel filter is going bad or clogged
so to feed my curiosity does anyone know how low the fuel pressure can be and the engine will still run even if not too great?
im sure if it was so low id be getting a lean code all the time just curious guys
thanks
Old Jun 22, 2008 | 01:28 AM
Anomaly's Avatar
Car: 1987 IROC
Engine: 383SR
Re: how low can the fuel pressure be to still run car?
well with my dieing fuel pump my car idled with 25psi ish... it didnt run well but it would run.
Old Jun 22, 2008 | 01:40 AM
Bobby_80s's Avatar
Axle/Gears: no idea
turned out to be a bad sender, but thanks for the info. nice to know the limits of your own engine
Old Jun 22, 2008 | 02:07 AM
Theking's Avatar
Car: 1989 IROC-Z
Transmission: Th700R4
Remember that to lean conditions like to low fuelpressure and so will melt the pistons, to much air and not enough fuel will be hot... just a reminder..
The Ford injectors, are they densos you have ? check on the side, If they are densos, dont go much over 39psi because they dont like it..
MustangBeater20
Oct 29, 2022 09:20 PM
specialized
Jun 18, 2022 09:26 AM
9192camaro
16
Feb 3, 2019 12:21 AM
86IROC112
Aug 17, 2015 02:00 PM
Kaweh
Aug 9, 2015 02:54 PM
