code 42 help?? runs great!?!?!
Old Jun 20, 2008 | 09:01 PM
jjskibbs's Avatar
Car: '89 IROC
Engine: 350 TPI 5.7L
Axle/Gears: axle?? got me.. 3.73:1 gears
hey guys. jsut installe dnew injectors in my 305tpi. bosch design III 19lb. the car runs and idles excellent!!! better than ever.
today was the 2nd day i drove it after the injectors and my engine light popped on - found a code 42, Fault at electronic spark timing circuit OR Fault at direct ignition system OR Fault at fuel cutoff relay circuit.
i checked to make sure i didn't forget a connection and all looks good except for a vacuum line i forgut on the bottom of the tb. the car runs great and didn't change when the light came on. so i am confused - -- is this coincidence or could i have caused something. i have also heard of the tps causing this code, but my tps is new and adjusted to .54v ( ireplaced it over a month ago and had no problem).
any ideas where i should start? i was thinking my est or ignition coil but that i would think would cause the car to not run right???? i'm lost...
also, i almost forgot... when i replaced the injectors i also ported out the shrouds in front of the egr port holes at the front of the plennum for more air flow and i also descreened my MAF and yes i made sure the little wires in the maf were ok before reinstalling.
Frozer!!!
Jan 19, 2024 04:55 PM
specialized
Jun 18, 2022 09:26 AM
Vintageracer
Jan 10, 2020 05:33 PM
justin57
Aug 20, 2015 07:05 PM
