Tough one i think!!
Old Dec 9, 2001 | 09:10 PM
BP89IROC's Avatar
Tough one i think!!
My car idles lower when it's cool outside. Is it just because the air is more dense or is my car not able to regulate the air enough to lower it in the summer. It is the most noticeable when you let off the gas to decelerate. I have way more compression break when it's colder outside than when it's hot. I know it's not much of a problem, i'm just curious! Thanks.
1989 Iroc-Z TPI 350 auto 4-spd Removed MAF screens K & N filters, Hedman smog shorties, accel 8mm wires, made for you wire looms, flowmaster american thunder cat back, gutted cat.
Old Dec 9, 2001 | 10:04 PM
breathment's Avatar
maybe its your MAT sensor. if it hasn't been replaced it might be coated in carbon.
- David
88' GTA 5.7L TPI MODS---> air foil, K&N, Shift Kit, 180* therm, TB bypass, Gutted CAT, Flowmaster 80 Series Muffler added to Unkown CatBack, Ported Intake
http://www.geocities.com/david_angel_16
Old Dec 10, 2001 | 10:39 PM
smokin87iroc's Avatar
Car: 87 IROC
Engine: 305 TPI going to LT1
Transmission: 5spd
i'm 99% sure the MAT sensor does nothing for a Mass Air car.
you car will make a little more power in colder weather than it will in warm weather so that could be what you are seeing.
Andrew
91 SrS
Oct 7, 2015 04:32 PM
roysatikas
Sep 22, 2015 08:15 PM
i8urrice
Oct 13, 2001 07:21 PM
RICHRAD
Apr 22, 2001 11:12 PM
Zandor7
Sep 22, 2000 11:03 AM
