Yellow/Orange spark at coil
Old Jun 23, 2008 | 12:18 PM
ROTICKA's Avatar
Car: 1984 T/A
Engine: 5.7L TPI
Hi again guys!
I think I've found a major component in my fuel mileage/miss at idle problem. I hooked a spark plug into the distributor end of my coil wire, and had someone crank the motor a few times. The spark was yellow/orange instead of blue/white. This coil was new 1500 miles ago (although cheap). I swapped the coil with an original gm coil my dad had lying around. Same thing. What are your suggestions? Should I check wiring or just buy another new coil?
Old Jun 24, 2008 | 09:34 PM
ROTICKA's Avatar
Car: 1984 T/A
Engine: 5.7L TPI
Re: Yellow/Orange spark at coil
So I did the 3 part coil test listed in the chiltons manual, my newer coil passed all three. I also did the coil winding continuity test. All terminals came out to 8.5 ohms. So the coil is good right? Where do I go from here?
RedLeader289
May 28, 2019 01:47 PM
Bubbajones_ya
Oct 25, 2015 08:01 PM
school boy
Oct 22, 2015 11:47 AM
HoosierinWA
Oct 7, 2015 10:15 AM
meeklay812
Oct 1, 2015 03:46 PM
