Walmart cheapo SuperTech Oil OK ?
Old Dec 12, 2001 | 12:23 PM
GTA88's Avatar
If I change my oil and filter every 3,000 miles, I would guess Supertech oil at 84 cents a quart would be OK, at least, not harmful to my engine, right ??? It has the same ratings as the other oils, like SF, SG, SH, etc. I don't race very often. Just the occasional stoplight dragrace. I almost never take it over 4K rpm, and seldom over 3K rpm. Thanks
btw, whatever happenned to the "Tech / General Engine " board ??"
88 GTA 5.7 TPI Charcoal Grey Bone Stock except for loose muffler which makes it a bit louder than normal.
[This message has been edited by GTA88 (edited December 12, 2001).]
Old Dec 12, 2001 | 12:29 PM
afgun's Avatar
Car: Non F-body :(
Engine: Pontiac 301
Transmission: TH350
If the oil meets current specs then there's no reason to not use it if you're cost conscious.
Old May 5, 2005 | 06:51 PM
Catchen22's Avatar
Car: 91 Camaro T-Tops
Engine: 3.1L
SuperTech is junk
I have no proof of this but I work at wal-mart and i've heard that the super tech oil filters are made by fram for wal-mart. If Fram is crap what do you think Super Tech is?
Old May 5, 2005 | 07:00 PM
Parrydise7's Avatar
Do a search. This has come up before. I don't believe that the Wal-Mart oil filter is made by Fram. At least in prior discussions it wasn't.
You might also want to check bobistheoilguy.com. That site has a good review of a variety of oils.
Old May 5, 2005 | 07:54 PM
EdgesZ28's Avatar
Car: 91 GTA - 94 TPI Suburban
Last time I researched SuperTech oil filters, it was my understanding that they are made by Champion Labratories. They also manufacturer filters for Mobil, AC Delco (overseas), Autozone, and a few others. Not saying it is the same filter in each case, but I believe the Autozone and SuperTech are the same filter. I wouldn't and don't hesitate to run them on my daily drivers. I'll stick with AC or Wix (Napa and Carquest) filters on my 383 Camaro though.
I believe that the following study is accurate and will represent similar hits if you Google "Super Tech Champion". Ed
Old May 5, 2005 | 09:07 PM
Parrydise7's Avatar
What he said.
jrdturbo
Mar 31, 2016 02:58 PM
skinny z
Oct 5, 2015 06:23 PM
meeklay812
Oct 1, 2015 03:46 PM
mfp189
Sep 27, 2015 09:25 AM
