what would be better
Old Jun 29, 2008 | 11:12 PM
alpine247's Avatar
Car: 1988 IROC-Z
Axle/Gears: 2.77 posi stock
i want more tq
so i was wondering what would be better, port the plenum and buy slp runners or just get the holley ram intake..
looking for the most TQ gain here thanks
Old Jun 30, 2008 | 12:13 AM
Shadygrady's Avatar
Car: 87 IROC Z
Engine: 5.7 L98 TPI
Transmission: 700r4,2500 stall
Axle/Gears: G80,10 bolt 3.42's
Re: what would be better
Niether one will give you much tourqe.May even lower your peak tourqe,but give you a broader tourqe curve,which is better than high peak numbers.Intake wise tpi is the better tourqe maker. and learn.If you get the runners and port the plenum go ahead and get the high flow base as well or you may not be see much of a gain
