Vortec, Vortec Bow Tie, AFR Help Me Select
Old Jul 8, 2008 | 10:02 PM
sol_searcher's Avatar
The engine is a stock 355 TPI from a 89 GTA. The engine and 700R4 are in a 88 Jeep YJ. This is a BAR approved smog-legal swap. I want to stay CA smog legal.
I would like a little more performance but don't want to sacrifice low-end performance and want to optimize torque from 1000 to 5000 rpm. I desire to achieve at least the 440 lb-ft of torque that Scoggin Dickey claims for their vortec TPI motor.
To do this I am planning head and cam replacement. I think I want to keep at of below 180 cc port volume to keep the intake velocity up for good low-end torque.
I see my choices as either the vortec or bow tie vortec head and a vortec TPI base. Or AFR 180 eliminator heads and extrude honed stock TPI base. Clearly, the AFR approach is more expensive but not a whole lot more.
I will be running custom made stepped, long-tube, 2-1/2"merge-collector headers with AIR fittings. Probably 1-5/8" to 1-3/4" although I will also consider 1-1/2" to 1-5/8" as torque and low-end are what I'm trying to optimize for. I know they are not quite smog-legal, but they might have an exemption number.
It is likely that I will run a single-pattern Mike Jones camshaft. I have been very impressed by 1989GTATransAm's thread on his 228/228 Jones camshaft. The AFR has better exhaust flow so maybe a single-pattern cam lends itself a little more to the AFR heads. The exact cam will be selected once a decision is made on which heads. I also don't mind paying for a custom grind if that is what is required. Also, I will change pistons to up the compression ratio if it is required to optimize the system. I am willing to run 91 octane but would prefer to optimize for 87 octane. Might have a hard time getting good gas in Mexico.
Which head/TPI manifold combination would you select and why?
Old Jul 9, 2008 | 01:52 PM
MedVader's Avatar
Car: 90 Formula hardtop
Engine: 5.0 TPI
Re: Vortec, Vortec Bow Tie, AFR Help Me Select
RHS Vortecs
http://www.competitionproducts.com/p...ber=RHS12410K1
$699 pair of assembled heads(Don't let the pic fool you. They're fully assembled)
Flow up to .600 lift while stock vortecs stop at .500.
Ed1LE
Sep 30, 2018 09:14 AM
Bohemian
Aftermarket Product Review
Nov 25, 2015 09:38 PM
oil pan 4
Fabrication
Oct 6, 2015 11:56 AM
ULTM8Z
Oct 2, 2015 01:25 PM
tcarlos13
Interior Parts Wanted
Sep 28, 2015 06:31 PM
