Do I need a different fuel pump for the FIRST Injection setup?
Old Aug 1, 2008 | 03:12 PM
Gunny Highway's Avatar
Car: 91 RS
Engine: 350 TBI
I currently have a 350 TBI, but I'm looking into the swap over to the FIRST Injection setup. Unfortunately since I no longer have a garage, I'll have to pay for labor for the install if I decide to go through with it. I have a Walbro 190 that I put in there about 4 years ago, so I'm unsure if that will do the trick or not. Could I just add an inline pump to help pull some more fuel?
And 2), what are the differences I'm going to have to take into account in regards to the fuel system/lines going from the TBI to the TPI?
Old Aug 3, 2008 | 10:10 AM
Car: 91 RS
Engine: 350 TBI
Re: Do I need a different fuel pump for the FIRST Injection setup?
Really? No one?
Old Aug 5, 2008 | 12:01 PM
Kevin91Z's Avatar
Car: 1990 Pontiac Trans Am
Transmission: Tremec T56
Axle/Gears: 12-Bolt 3.73
As long as that Walbro 190 is capable of putting out 50+ PSI, it'll work with the TPI injection. If its a 15 PSI TBI pump, you'll need to change it.
The fuel lines are the same. You'll be fine there.
Glowsock
Jul 24, 2025 03:15 PM
92camaroJoe
Jul 29, 2023 07:57 PM
evilstuie
Jan 9, 2020 08:29 PM
9192camaro
16
Feb 3, 2019 12:21 AM
92camaroJoe
Aug 13, 2015 06:07 AM
