How to remove passenger runner bolt
Old Aug 9, 2008 | 07:06 AM
dp149's Avatar
I have a 1991 camaro 5.0 liter tpi that i am swapping injectors this weekend. Got plenum and driver side runner off but how do I access that lower torx bolt on the passenger side at the front? I tried extensions and flexible ujoint but my t40 head cant get to it?
is their a trick to getting this off..very frustrating or can I leave that passenger runner in place and still remover the fuel rail?
any advice would really help.
thanks
Old Aug 9, 2008 | 09:27 AM
Viprklr's Avatar
Car: 92 GTA/ 00 TA
Engine: 383/350
Transmission: 700R4/T-56
Re: How to remove passenger runner bolt
Remove whatever is blocking you.
There is no trick. Just use an extension with the torx bit.
Old Aug 9, 2008 | 09:43 AM
Thirdgen89GTA's Avatar
Car: 1989 Trans Am GTA
Transmission: M28 T56
To get the inner torx bolts you need an extension and you have to do it from the opposite side of the car. If its on the passenger side you need to use and extension and get to it from the driver side as Viprklr said.
After you've done it a few times you should be able to rip the intake off a tuned port car in less than 10 minutes. Its easy.
Old Jul 14, 2011 | 02:56 AM
george88gta's Avatar
Car: 1988 Pontiac GTA
Engine: 5.7 l98
Axle/Gears: BW 9bolt with torsen carrier
ok, I know really old post but I having trouble finding a way to get the lower passenger bolts off. I have done it before. but to not remember. 1 guy said take off valve cover off. but I know thats not how I did it. anyone remember what they used?
Old Jul 14, 2011 | 07:58 AM
A ratchet and a torx bit.
The lowers are easy, the uppers are easy. The hardest are the inside bolts that must be reached from the opposite side of the car.
IROCZDAVE (88-L98)
Oct 6, 2016 09:08 AM
Eric-86sc
Apr 3, 2016 03:52 PM
LittleFranks
Aug 20, 2015 03:55 PM
Street Lethal
Aug 14, 2015 08:25 PM
3rdgenparts
Aug 8, 2015 07:09 PM
