I recently got a 87 Iroc that has been sitting for 10 yrs. It was a 305 tpi and now it appears to have a gm crate replacement motor in it, its now a stock 350 with headers, my question is this. I want to replace the injectors with new ones, so what size should I go with and who make a good set of injectors??. I am thinking 22lb injectors am I right or wrong??...Thanks for the help!!
Quote:
this is the best injector place.. great service tooOriginally Posted by NY87Iroc
I recently got a 87 Iroc that has been sitting for 10 yrs. It was a 305 tpi and now it appears to have a gm crate replacement motor in it, its now a stock 350 with headers, my question is this. I want to replace the injectors with new ones, so what size should I go with and who make a good set of injectors??. I am thinking 22lb injectors am I right or wrong??...Thanks for the help!! http://fuelinjectorconnection.com/sh...&productId=134
305 Irocs use 19lb injectors and 350 uses 22lbs?? Is this correct??...Thanks!!
Quote:
thats correct.. get the bosch III from FIC.. they are the right height to drop in with no mods,Originally Posted by NY87Iroc
305 Irocs use 19lb injectors and 350 uses 22lbs?? Is this correct??...Thanks!! Thanks alot!!
