intake manifold mod
Old Sep 4, 2008 | 08:23 PM
2bfeard's Avatar
Car: 1986 iroc
Engine: 350 .060 AFR HSR XFI280
Transmission: transgo 700r4
intake manifold mod
hi everyone i was wondering if its possible to modify an early tpi manifold to fit later style heads with center bolt covers? is there enough material by the two center bolts on manifold to remove so i can bolt it to the heads? and if so whats the easiest way to do it?
Old Sep 4, 2008 | 10:07 PM
vetteoz's Avatar
Car: 82 Z28
Engine: 383 SP EFI/ 4150 TB
Transmission: T400
Axle/Gears: QP 9" 3.73
Re: intake manifold mod
Most just drill the holes out large enough to take the different angle
Old Sep 4, 2008 | 11:17 PM
2bfeard's Avatar
Car: 1986 iroc
well ive tried to do it but its way too much material i need to remove. does anybody have a picture so i can see how it was done?
Old Oct 27, 2008 | 02:01 AM
therealmark's Avatar
I'm in the same boat. Late TPI on early heads there's a ton of material because you're going in the other direction.
Here's the issue with early TPI on late heads.
There's not really much metal there to remove.
I'd also love to hear how people have worked around this.
M.
Bubbajones_ya
Aug 31, 2015 12:02 PM
The Tank
Aug 30, 2015 06:16 PM
Bubbajones_ya
Aug 28, 2015 02:17 AM
theurge
Aug 21, 2015 12:46 PM
Jake_92RS
Aug 11, 2015 10:39 AM
