91 GTA need help
Car: 91 Trans Am GTA
Engine: 5.7 TPI
Axle/Gears: 373 posi disk brake
91 GTA need help
hey whats up guys im a new guy on here but i have a big prob if i come out in the morning and start my car she runs great i can rev it still sounds great...... BUT.... once it warms up it seems to get a misfire and if you rev it and let off it backfires like crazy... but if you unhook the O2 sensor its seems to run better but i still get that misfire any idea's???? below are a list of this already replaced
plugs,wires,cap,rotor,new pick up,new module,new o2,new computer,new aic,new map,new tps,new cooling temp sensor,new fuel filter....
note i also waited for the misfire and unpluged each injector and they all made a diff some more then others... i was thinking bad injector but wouldnt it do it all the time?????
compression test was perfect across the bord so please any idea"s??????
Transmission: Pro-built 700R4
Re: 91 GTA need help
Have you checked the knock sensor? After the engine is warmed up, it will switch open/closed loop and start taking input from the knock sensor. If there are issues from it, that can cause the system to adjust for the knock.
Engine: 5.7 TPI
all sensors were new lol fixed the prob today.... i got a free set of LT-1 injectors for free replaced my old ones she will not spin the tires from a 20mph roll start
thanks for all the help guys
thanks for all the help guys Thread
2012sergen11
Oct 13, 2015 07:38 PM
