83 camaro wont start
Old Sep 24, 2008 | 05:02 PM
mike's 83 iroc's Avatar
Bought a 83 camaro with a v8 tpi engine that sat for 2 years without running. seller said he couldn't start vehicle either. car starts when spraying starting fluid into throttle. figured out bad fuel pump and replaced it. car starts now but turns off after a few seconds(1-2 sec). need help figuring out what is wrong with it.
Old Sep 25, 2008 | 05:11 PM
stealth908's Avatar
Car: 87 GTA
Engine: tpi 350
Re: 83 camaro wont start
Check the Fuel pressure. 43 psi. Did you pump the old gas out?
Old Sep 25, 2008 | 06:08 PM
Re: 83 camaro starts but turns off immediately
Checked fuel pressure and has brand new gas. Does anyone think that it might be bad plugs? Took off #1 plug and was "dirty" black- not oily just dirty.
Old Sep 25, 2008 | 07:22 PM
MCWOOD2006's Avatar
Car: 1988 Chevy Camaro
Engine: 5.7l 350 Small block
Transmission: 700r4 soon to be tci street fighter
Mike,
the just dirty plug is nothing serious. just change'em. i had the same problem on my 88 tpi. replaced the fuel pump. then car sputtered and cut off a few seconds later. then i replaced my distributer (the only thing left considering if it doesnt run its either no fuel or no fire. if it turns over good then i would say put a new distributer in it. i put a Msd in mine and denso iredium plugs and she purrs like a kitten.
Frozer!!!
Jan 19, 2024 04:55 PM
92camaroJoe
Jul 29, 2023 07:57 PM
Caspar
Jun 19, 2016 11:19 PM
92camaroJoe
Aug 13, 2015 06:07 AM
