TPI Engine Bay Cleanup
Old Jul 9, 2009 | 08:54 PM
  #51
HCR13's Avatar
Car: 1987 Trans Am
Engine: 355ci L98 soon to be turbo'd
Axle/Gears: 2.73 posi
Re: TPI Engine Bay Cleanup
I figure I'd revive this thread since I'd like to see more TPI engines... Here is where I currently am now. I've deleted smog pump, and heater vavle and ac for now, I plan to retrofit a new ac system. I've also removed the windshield cleaner bottle and relocated the coolant overflow tank. I've relocated the cruise control lower. I've tried to clean up all the extra nonsense wiring and ziptie the rest. I have a CS series alternator aswell. I have a hard line copper coolant line from the intake to the heater core... I plan to paint the intake eventually. When the engine is pulled the engine bay will get a serious cleaning. First pic is what I started with, how it looked when I bought it, the other three are now...
Attached Thumbnails TPI Engine Bay Cleanup-engine-bay2.jpg   TPI Engine Bay Cleanup-engine-bay1.jpg   TPI Engine Bay Cleanup-engine-bay3.jpg
Old Jul 9, 2009 | 08:57 PM
  #52
HCR13's Avatar
Car: 1987 Trans Am
double post
Old Jul 10, 2009 | 09:27 AM
  #53
88fastgta's Avatar
Car: 1988 Flame Red Trans am GTA
Engine: Forged 355 4 Bolt, FIRST TPI
Axle/Gears: ls1 torsen 3.42 gear
Here is my engine bay as of now..... real clean this is after my engine swap... deleted tons of things.....
Old Jul 10, 2009 | 12:45 PM
  #54
HCR13's Avatar
Car: 1987 Trans Am
my main goal was to be able to see BOTH valve covers clearly...
Old Jul 10, 2009 | 05:43 PM
  #55
sadler's Avatar
Car: 1988 Iroc-Z
Engine: 5.7l 350 TPI
Transmission: 700R4 Auto
Axle/Gears: 3.43 posi
But seriously, how do I get those two things off my pass side valve cover, what would i use to plug it up and what are they called again?
Old Jul 10, 2009 | 06:40 PM
  #56
HCR13's Avatar
Car: 1987 Trans Am
what are you referring too? The coolant lines? The wiring? the A.I.R. stuff? heater valve?
Old Jul 10, 2009 | 07:02 PM
  #57
blacksunshine'91's Avatar
Transmission: Pro-built 700R4
Originally Posted by HCR13
Where did you get that throttle body cover plate? Is that the one Hawk's sells?
Old Jul 10, 2009 | 08:36 PM
  #58
HCR13's Avatar
Car: 1987 Trans Am
nope, Hawks would probably sell them for $99.99. Got it off ebay, just type in "TPI Plate" and it'll come up
Old Jul 10, 2009 | 09:34 PM
  #59
SMURFN' Z28's Avatar
Car: 1994 Jeep Wrangler
If you don't daily drive it, yank away! That said, I am sort of pissed that I pulled the working A/C and cruise control in the name of weight reduction.
It all sort of snow balled when I started modding my car... it was one of those well am doing this..... I may well do this...
If a car is not daily driven, it is hardly making any negative environmental impact. I am not sure how many other states are like the PRC (Peoples Republic of California) but unless they do a visual inspection, you can easily pass with only a cat if your car is in tune.
As for the charcoal canister, I yanked mine and stuck the vent line that went to it into the fender up by the head light. And no, I do not smell gas or flammable vapors.
Old Jul 10, 2009 | 09:49 PM
  #60
Close, it was $40 but it wasn't that exact color combo. Yours was exactly what I have been looking for. Thanks for the link. How was the quality of the product and fit?
Old Jul 10, 2009 | 10:05 PM
  #61
sadler's Avatar
Car: 1988 Iroc-Z
Well i finally did the heater core which ive been bitching about, now time for whatver is all that rubber tubing right above the valve cover, one this comes right off the manifold one just looks like a tangle of **** lol
Before
After
Old Jul 11, 2009 | 01:25 AM
  #62
HCR13's Avatar
Car: 1987 Trans Am
looking good everyone. I am going to try to retrofit a newer ac system, maybe from a late 90's GM car and swap most of the components...
Old Jul 11, 2009 | 01:33 AM
  #63
gurkgurkgurk's Avatar
Car: 86 Camaro iroc-z28
Axle/Gears: 3.42 Posi
you can just ditch the charcoal canister and get a vented gas cap instead. it aint much better for the atmosphere but i think itd be safer.
anyways
i so far have bypassed my heater core (it broke and started leaking and i was too lazy to fix it) and i got rid of my AC stuff which i have for sale currently. but something i noticed is what do you do with that little bracket that holes up acouple of lines from the charcoal canister?
Old Jul 11, 2009 | 10:21 AM
  #64
89ROC-Z's Avatar
Car: 89 IROC-Z
Engine: 370 LSX, LS3 Top End
Transmission: Built T-56
Axle/Gears: 9" Aluminum Center 3.89's
I think i got mine pretty good.
Old Jul 11, 2009 | 08:42 PM
  #65
SystemX's Avatar
Car: 1989 Pontiac Trans Am GTA
Engine: 5.7L L98
Axle/Gears: 3.27:1
Hi Gang! Lots of good ideas here. I'm currently working on putting headers in my 89 GTA and I've pretty much ripped out all the non-essentials: A/C, Smog/AIR, Power Steering, etc.
Here's where I need a little help.
I would like to run just the alternator and water pump. I want to relocate the alternator to the passenger side with an adjustable mounting bracket. From what I've seen, quite a few of you have done this and I it looks simple. I just need to know what to steal the bracket off of. Just a carb Camaro/TA or an old chevy truck?
Also, for the water pump, it looks like some of you have re-used the A/C pulley on the water pump. Did you have to hook up power to the cluch or was it done some other way. Maybe the A/C pulley isn't even used and just looked that way.
Going to this configuration also obviously reverses the water pump rotation so I would need a new water pump. Again, do I just use an old carb camaro/TA or one from a chevy truck?
TIA for all your help. I'll post some pics when I finish up.
Old Jul 11, 2009 | 11:42 PM
  #66
HCR13's Avatar
Car: 1987 Trans Am
well, to answer your question in my case, my car with with vbelts so the alternator was already on the passenger side. Just go to the junkyard and find a mid 80's sbc from a GM vehicle, many of them have vbelts and use those brackets. Many people with the serp also need an A/C delete pulley...but not if you have vbelts....
Old Jul 16, 2009 | 05:25 PM
  #67
hellz_wings's Avatar
Car: 1986 Chevrolet Camaro IROC-Z28
Engine: TPI 310ci (LB9)
Transmission: Custom Rebuilt 700R4 - 2600 Stall
Axle/Gears: 10 bolt, 3.73 Eaton Limited-Slip
I will post pics of my engine bay once I get back from vacation.. Gotta clean off all th dust i haven't driven the car in 3 weeks! shame on me! :O
Old Jul 16, 2009 | 06:35 PM
  #68
Daniel Doerksen's Avatar
Car: 1986 T/a
Engine: 5litre TPI
Transmission: T-5 5speed
Axle/Gears: 3.42 1999sscamaro torsen lsd
Browsing through this thread mines a 1990 5.0tpi swapped into my 86T/A im just finished the swap then im touching up the black... but one way to get rid of clutter is to get rid of serpitine belts... and remove ac/ and airpump.
keep in mind im still working on my harness so its spread in some areas
Old Jul 24, 2009 | 03:58 PM
  #69
omnipotentgoku's Avatar
Car: 1987 IROC Z
Engine: 350 TPI L98 block
will take some pics and post em later.
Old Jul 28, 2009 | 07:41 PM
  #70
SystemX's Avatar
Engine: 5.7L L98
Axle/Gears: 3.27:1
Well I've gotten my headers installed and finally gotten around to taken a couple pics of my engine bay. As I said earlier I've prettyr much removed everything non-essential including A/C, Power Steering, AIR, etc. I relocated the alternator to the passenger side with a mid mount bracket and got a 42.7" belt. I swapped out my water pump for a normal rotation pump. Everything else is pretty much stock (L98) with the exception of my BoschIII injectors from FuelInjectionConnection.com and BBK AFPR.
Sadler, if you need some help with removing things from under your hood PM me and I'll try to help you out.
Here's some link to full size versions of these pics. Warning - very large!
http://home.comcast.net/~wiz34251/Dbay1.jpg
http://home.comcast.net/~wiz34251/Pbay1.jpg
Old Jul 28, 2009 | 09:33 PM
  #71
88fastgta's Avatar
here is mine....
Old Jul 29, 2009 | 03:01 AM
  #72
Shadygrady's Avatar
Car: 87 IROC Z
Engine: 5.7 L98 TPI
Transmission: 700r4,2500 stall
Axle/Gears: G80,10 bolt 3.42's
Why did you remove the power steering pump on a stock engine?FASTGTA,LOOKING GOOD.I think I bought my TPIS lower manifold from you.Thanks,should be finished porting it this weekend.
Old Mar 29, 2010 | 08:56 PM
  #73
mrcleans's Avatar
hey, my wife and i are new owners of a 1989 trans am gta. i came across this site and like it. first thing i am looking to do is clean up the engine bay and delete the a/c and the AIR system. where are you guys getting your delete pulleys from?
edit: nevermind... search owns me. thanks
Old Mar 30, 2010 | 08:28 AM
  #74
tenpin842's Avatar
Car: 1987 Trans Am
Engine: 5.0L TPI
Axle/Gears: Richmond 3.73
yeah I'm clean LOL!!
Vintageracer
Jan 10, 2020 05:33 PM
Reddeath210
Oct 6, 2015 08:20 AM
AkDrifted
Aug 17, 2015 07:45 PM
jahblah
Aug 12, 2015 05:54 PM
Sanjay
Aug 12, 2015 03:41 PM
