roller rockers on stock heads
Old Oct 4, 2008 | 12:49 PM
91firebird350's Avatar
Car: 91 Firebird Formula 350
Engine: TPI 350
Axle/Gears: 3:23
Hey crew
I was just curious if removing the heavy stock rocker arms and replacing them with roller replacements would help the motor run better.
im not sure what size is on there but im guessing 1.5. which would be better to install - 1.5 or 1.6 and what brand. i see a lot of comp and crane ones.
thanks for the help.
Mark
Old Oct 4, 2008 | 03:37 PM
Chevhead89's Avatar
Re: roller rockers on stock heads
stock engine? dont waste your time and money.
Old Oct 4, 2008 | 08:46 PM
Engine: TPI 350
Axle/Gears: 3:23
she does have a few mods but nothing along the lines of heads and cam
Old Oct 5, 2008 | 03:33 PM
Chevhead89's Avatar
ya put the money someplace else.
Old Oct 5, 2008 | 08:58 PM
Damon's Avatar
Generally agreed. I've found a few ponies by going to a set of 1.6 ratio rockers with a stock cam. The extra lift doesn't hurt. A set of stamped steel roller-TIPPED rockers from Comp or off-brand are a budget bolt-on upgrade without having to deal with clearance issues of big fat aluminum body full roller rockers. You'll need them to be self-aliging rockers for your year of engine in any case.
Link to a set of Proform rockers like I described:
http://store.summitracing.com/partde...C&autoview=sku
Comp makes a set, but it's 2 bills+:
http://store.summitracing.com/partde...6&autoview=sku
Crane also makes a set of narrow-body full roller aluminum rockers in your choice of 1.5 or 1.6 ratio but you will likely have sticker-shock at the price. Definitely not a bang-for-the-buck champion on a near-stock engine.
midge54
Dec 27, 2019 04:14 PM
theshackle
Mar 5, 2017 06:37 PM
sweet_87_iroc
Sep 25, 2015 10:01 PM
camaro71633
Sep 1, 2015 10:24 AM
IrocZ'85
Aug 17, 2015 06:24 PM
