NEED HELP ASAP..WHAT IS THIS PART?!
Car: 86 camaro irocz z28
i have a 87 l98 and 2 days ago my car started running like s***. it is hard to start and once it does, i need to give it gas or it dies out, and i smell a strong gas smell. so i looked around and found a cirlular part behind the plenum in front of the distributer. it is leaking gas and i have no idea what that is. can someone please give me some info. thanks
Re: NEED HELP ASAP..WHAT IS THIS PART?!
if it is a ruptured diaphram then it definitely will spew and cough. Pull the vacuum line off and crank it up. If it is a ruptured diapram then gas is going to blow out where the hose was connected. BE CAREFULL... Lay a rag arond it so you don't explode the thing into a flame ball. It wont be pretty.
LT1Formula
20
Nov 14, 2015 12:02 AM
Thomas
Oct 3, 2015 05:34 PM
