Please help! 92 GTA mystery
Old Dec 7, 2008 | 07:00 PM
David92GTA's Avatar
Im having a problem with my car starting I have ignition its turning over but I dont think the injectors are firing what would cause that? Would this be the nuetral safety switch? if not please leave me some input
PLEASE LEAVE ADVICE!
thank you in advance for any input you have
Old Dec 7, 2008 | 07:16 PM
jermdm's Avatar
Car: 1989 Iroc-z
Transmission: Auto 700R4
Axle/Gears: 9 bolt - 2.77
Re: Please help! 92 GTA mystery
Its not going to be the neutral safety switch. That keeps it from cranking when the trans is in gear. Can you hear the fuel pump prime when you first turn on the ignition? Should hear it for about 2 seconds. Check for fuel pressure. If you think its a fuel problem or injector problem, try squirting some starting fluid in the throttle body to see if it starts up.
Old Dec 8, 2008 | 03:18 PM
jsmith929's Avatar
Car: 88 gta
Engine: 5.7
Transmission: 700r4 with 2400 stall
Axle/Gears: 9 bolt 3.23
Check that you have spark not just the starter is turning over.
Old Dec 9, 2008 | 12:35 PM
jamon8's Avatar
Car: 88 GTA "Cocaine"
Engine: 350 tpi
buy a noid light the helms manual and a spark checker
telling us you dont know if the injectors are getting pulse without spending the 8 bucks for the niod light is wrong
you know what put the computer next to your car and well fix it for you
Old Dec 10, 2008 | 06:37 PM
89junkyardgta's Avatar
Car: 1989 GTA, 1985 T/A
Engine: L98, LG4
Transmission: Slush-o-matic 700R
Axle/Gears: stock and stock
Here, try this. Get someone to help you. Take a sparkplug out before starting the car. With the plug still plugged into the wire, hold the plug the exhaust manifold or another ground and start the car. If it sparks, you have spark, if it doesn't, then you need to check your coil and wires. Everyone else on the thread is right about the fuel. When you turn the key on, you should hear the fuel pump prime up. If the pump primes and the car still doesn't start, put the plug back in and crank the car over a few times. Pull the plug out. If its wet and smells like gas, you are getting fuel. And yes, as jamon8 said, spending a couple bucks on some diagnostic tools would help, both us and you. Good luck.
F-body-fan
Jan 12, 2023 01:49 PM
sheachopper
Jul 31, 2019 11:27 AM
bjpotter
Oct 4, 2015 07:48 PM
Navy8125
Exterior Parts Wanted
Oct 1, 2015 11:24 AM
Gordonr1973
Sep 29, 2015 11:59 AM
