Timing question
Car: 1971 Camaro
Timing question
I have a 90-92 SD TPI installed in my 82. Custom chip.
I unplug the est connector and set the base timing at 6 degrees BTDC. When I plug the connector back in the timing jumps to 28 degrees BTDC.
I was wanting to make sure this is normal .....because my car runs like crap right now and everything is new....I wanted to check this first before I start troubleshooting other things.
Thanks!
Thanks!
Re: Timing question
Thanks!
Thanks!
you in the clear, mang.
