Need advice
Old Jan 21, 2009 | 03:27 PM
etro1955's Avatar
Need advice
I have a 91 z28 with the 305 tpi and i need advice on what performance parts to buy. (nothing too radical)
I do not plan to swap a new engine in anytime soon and allready have a 3.73 posi rear.
im looking to get the car in the lower 9 second range in the 1/8 mile.
thanks
Old Jan 21, 2009 | 03:34 PM
Ca[maro]88's Avatar
Car: 1988 Camaro Sport Coupe
Engine: 5.0 305 Carb'd
Re: Need advice
the 9 second range is a little far without swapping to the 350. if you want, you could get a really nice cam, port your heads, get a nice set of headers and an exhaust. get some better rockers. if you plan on gettin a bigger cam, get a more powerful fuel pump. if you wanted i guess you could bore your engine out .030 over. i wouldnt go anymore than that though, the 305 block has less room to bore out than the 350. if you ever do plan on gettin a 350, the cam an head will bolt up to it so you dont have to re-buy everything. a good set or tires to hook up on the launch will help. if you do all that you MIGHT be in the 11-12 second bracket. if you want 9's then your gonna have to put a 350 or 383 in and bore the hell outta them.
Old Jan 21, 2009 | 03:55 PM
etro1955's Avatar
Re: Need advice
lower 9 second range in the 1/8 mile is a far reach for a 305? because it took it to the track last weekend and ran a 10.09
Old Jan 21, 2009 | 04:08 PM
Ca[maro]88's Avatar
Re: Need advice
OHHHH! sorry i missread. i thought he said 1/4 mile!! my bad my bad.
HoosierinWA
Oct 7, 2015 10:15 AM
jaridjohn
Oct 5, 2015 07:01 AM
gord327
Sep 29, 2015 10:18 PM
IROC ZELLER
Sep 29, 2015 03:00 PM
mrdevontay
Sep 2, 2015 08:04 PM
