New to TPI
Old Jan 21, 2009 | 08:19 PM
turbo11g's Avatar
New to TPI
I all, I'm looking at building a TPI motor. I don't have the money to build a roller motor, but would like to run a solid lifter cam. I'm thinking a 383 or a 377 ci motor with some double hump heads, and nitrous. I'd like 350-400 hp before the nitrous shot. What do I have to do to make this work? injectors, fuel pump/regulator, computer programming.
Old Jan 21, 2009 | 08:51 PM
burnout88's Avatar
Car: 88 IROC
Axle/Gears: 10 bolt 3.73
Re: New to TPI
Soild lifter is usually not a good match with TPI. You get alot of valve train noise with a solid lifter motor. Could mess with the knock sensor. You also tend to get low vaccum depending on your duration with with soild lifter. If money is tight I would recommend the below year one crate motor that puts out 415HP (dyno'd) for less then 3k and this motor will work great with TPI or Fuel injection. It's bascially a LT4 hot cam hyd. roller motor with some tweaked out vortec heads. A proven 400hp combo and it also has alot of vacuum.
CT350PC1 Year One Power Crate 400hp 350 crate engine assembly. $2989.00 Click on the link and scroll down on the yearone web page.
http://www.yearone.com/serverfiles/f...26DK73488&trk=
Features a 4-bolt main 350 block bored 0.030 over. It produces 12hg inches of vacuum at 800RPM--perfect for power brakes. Each engine is balanced and blueprinted and comes with a 12mth/12,000 mi warranty. It is dyno-tested and supplied with printout of your engine's results.
Note: Must use melonized distributor
Engine Specifications:
Horsepower: 400+
Torque: 400+ ft/lbs
Compression ratio: 9.5:1
Dyno-tested: Yes, includes balancer and 14" flexplate
Dyno sheet: Included with engine's output
Vacuum produced: 12hg @ 800RPM
Recommended fuel: 92 octane
Max recommended RPM- 6000
Block: Seasoned 4-bolt iron
Crankshaft: Nodular iron
Pistons: Hypereutectic
Connecting rods: Powdered metal
Camshaft- Hydraulic roller
Valve lift:.520"
Duration @ .050" (int/exh): 218deg/228deg
Rocker arms: Stamped steel 1.6:1 ratio
Cylinder heads: Ported Vortec
Valves: Stainless steel 2.02 int/1.60 exh
Valve springs: Heavy duty
Bore x Stroke: 4.030" x 3.48"
Intake manifold: Dual-plane aluminum
Oil pan, timing cover, valve covers included
Engine f
Part # Description Price Add to Cart
Old Jan 25, 2009 | 04:31 PM
birdtojag's Avatar
Car: 87 Firebird, 90 bird coming soon
Engine: 355 Chevy Vortec Heads TPI, LT1 inj
Axle/Gears: 2.77 posi 9-bolt
Re: New to TPI
Either that or get a roller block from a bone yard (usually from a truck with center bolt valve covers and 1 piece rear main seal). Would have to get the lifters, web and dog bones from a 305 or 350 camaro of firebird 87 +. Also would need to get a cam retainer plate that is under the timing chain in front of the block. This would be your cheapest thing to do. Then rebuild it with the goodies and heads and whatever. Good luck with your build. I'm putting together my engine this way and is turning out good so far.
Old Jan 25, 2009 | 04:43 PM
turbo11g's Avatar
Re: New to TPI
I just bought a 92 5.0 TPI motor and tranny. This is a hydraulic roller motor, right? It has 73000 miles and I got it for $500. I have found the aluminum heads at enginekits.com. Still looking for a forged rotating assembly and the right cam for what I want to do.
stalkier
Dec 6, 2015 11:25 PM
ChaseDale3and8
Sep 1, 2015 01:49 PM
Keith5
Aug 27, 2015 04:37 PM
theurge
Aug 21, 2015 12:46 PM
Sanjay
Aug 12, 2015 03:41 PM
