bogs at mid-high rpm
Old Mar 4, 2009 | 07:42 AM
goleafsgo143's Avatar
Car: 86 Iroc-Z
Engine: L98 350 TPI
Transmission: 700R-4
Axle/Gears: 3.23 Posi
hey guys, i installed my 350 tpi into my iroc, it is moreless a stock engine except an intake manifold and runners upgrade. It starts and idles fine, and i am able to rev it in park no problem up to about 5000 rpm. But when I put the car in drive and floor it, at about 3800-4500 it sounds almost like it hits a rev limiter and has no power, it almost sounds like a popping sound. Does anyone know what my problem could be? As I said it only happens under load in drive, not in park. I appreciate all the help. Thanks
Old Apr 15, 2009 | 11:09 AM
sd88formula's Avatar
Car: 1888 firebird formula
Engine: 350ci 5.7L tpi
Transmission: 5 speed
Axle/Gears: 12 bolt posi track
Re: bogs at mid-high rpm
have u checked the coil pack? had a caprice with that problem
Old Apr 15, 2009 | 11:24 AM
mpb74's Avatar
Car: 1986 Iroc-Z
Engine: 355 Phase 2 Bowtie heads
Axle/Gears: 342
i dont know anything about tpi, but with a carb this would mean your getting too much fuel too fast. good luck
Old Apr 15, 2009 | 03:25 PM
Car: 86 Iroc-Z
Engine: L98 350 TPI
Thanks guy I've since then solved it.. it was an ignition problem. I changed my ignition module and that fixed it. I guess it didnt have enough spark at the higher rpm.
Old Apr 16, 2009 | 10:23 PM
IROCmyZ90's Avatar
im having a similar problem but it has a new ignition module in it anything else it could be? it idles great like like your until it is put in gear.
Old Apr 17, 2009 | 06:40 AM
Car: 86 Iroc-Z
Engine: L98 350 TPI
just start with the basics, make sure you're getting fuel (injectors and fuel pump ok?), make sure youre getting spark (which you are it sounds like as it idles) but also check your coil if you changed your ignition module already..
Old Apr 30, 2009 | 11:11 AM
IROCmyZ90's Avatar
it has a new ignition module in it thats where im stump then someone tried to tell me it was mass air but the 90's dont have it. do you think it could just be bad plugs and wires.
pjsparts
Oct 29, 2025 06:39 PM
Grant2k
Apr 4, 2016 08:21 AM
RedLeader289
Sep 23, 2015 06:50 AM
wisemanz28
Sep 20, 2015 01:26 PM
middian
Sep 5, 2015 01:42 AM
