Help 87 MAF TPI Problems
Old Mar 10, 2009 | 09:01 AM
aldixie's Avatar
Car: 1991 RS Camaro Convertible
Hi Guy's,
I'm having problems with a project I'm working on. Have a newly rebuilt 305 with MAF TPI. Its running on a painless wiring harness. Replaced MAF burn off relay as it was pulling that code. Now have no fault codes but its running crap.
Also replaced Distributor cap, rotor and leads.
Car is difficult to start and won't idle properly. If I give it some gas it seems to hesitate before eventually picking up. At Idle it surges and falls back and then will die. Checked all of the vacumn lines for leaks and none found.
I'm even considering swapping it to Carb if I can't resolve the problems.
Help!!
Thanks,
Alex
Old Mar 11, 2009 | 08:26 AM
aldixie's Avatar
Re: Help 87 MAF TPI Problems
I read on here about injectors going bad so I did a resistance check. All of the injectors read around 16.2 Ohms. So no broken coils.
89GTAOz
May 16, 2020 09:31 AM
86IROC112
Sep 7, 2015 01:37 PM
NBrehm
Aug 25, 2015 11:49 PM
perZ
Aug 15, 2015 01:17 PM
Sanjay
Aug 12, 2015 03:41 PM
