Bad miss fire under load
Old Mar 13, 2009 | 06:51 AM
tummyson's Avatar
Car: 89 IROC
Transmission: 5 Speed
Axle/Gears: 3.08 Posi
Car runs great when its cool ,approx. 5-7 minutes.
Once it warms up I have a crazy misfire, like its only running on 4 cylinders. If I stay in it around 4500 rpm the misfire disappears and the car pulls to 5500rpm no problem.
New Bosch 19lb injectors and tune up 10K ago. I'm going to do the fuel filter this weekend and maybe order a AFPR.
Any thoughts.
THX>
Old Mar 13, 2009 | 07:19 AM
tummyson's Avatar
Car: 89 IROC
Re: Bad miss fire under load
...I forgot to say that if you rev it from idle in neutral it revs with out the misfire. Driving under load is when its missing. Even at an even speed it doesn't miss only once you start accelerating.
THX.
Old Mar 13, 2009 | 12:35 PM
Chevy8588's Avatar
Car: 1987 Iroc Z28/ 1982 Z28
Engine: 355 TPI IP/ 305 CFI
Transmission: T-56/ 300C
Axle/Gears: 3.42 Open/ 3.73 Posi
ohm out your injectors, if you find anything lower than 14-16 ohms, replace its but do it when the engine is hot, sounds like your injectors are $hit
Old Mar 13, 2009 | 03:43 PM
tummyson's Avatar
Car: 89 IROC
I'll check them out tomorrow. The injectors only have 10000km on them and were bought brand new
Any other suggestions?
Old Mar 15, 2009 | 05:55 PM
tummyson's Avatar
Car: 89 IROC
checked all the injectors after the car warmed up 15.2-15.4 ohm across the board.
Could a bad O2 sensor be the culprit?
1992Vortec
Aug 31, 2015 08:05 PM
Jae992
Aug 27, 2015 09:07 AM
Thornburg
Mid-West Region
Aug 25, 2015 08:20 PM
86IROC112
Aug 21, 2015 07:20 PM
Bryan F
Aug 18, 2015 02:28 PM
