belt size question
Old Mar 18, 2009 | 10:14 AM
88fastgta's Avatar
Car: 1988 Flame Red Trans am GTA
Engine: Forged 355 4 Bolt, FIRST TPI
Axle/Gears: ls1 torsen 3.42 gear
belt size question
whats up.. i deleted the passenger side bracket because i dont have ac or the smog pump and i was wondering is it possible to have a belt size thats only big enough to fit the alternator, waterpump, crank and power steering pump pulley...... oh and i guess the idler pulley things is gone to so it would need to be taken off by hand...
Old Mar 18, 2009 | 12:02 PM
305sbc's Avatar
Car: 1986 Irocz
Axle/Gears: 3.25:1
Re: belt size question
Without a tensioner you'll have to build some adjustment into one of the other brackets so you can tighten the belt. You also need to ensure that each accessory is spinning in the correct direction it was designed for. If you can satisfy those requirements then run a string around the proper belt routing and measure it. Belts come in all sizes.
Old Mar 18, 2009 | 12:12 PM
88fastgta's Avatar
actually now that i actually looked and put it back on i think it will just stick with the bracket and my delete pulleys.... thanks anyways...
toronto formula
Nov 10, 2015 06:17 AM
redmaroz
Aug 16, 2015 11:40 PM
Feffman
Mid-West Region
Aug 13, 2015 07:12 AM
Feffman
Aug 13, 2015 07:11 AM
knight72
Aug 10, 2015 09:32 PM
